Logitech Z906 Not Powering On Issue
dannnnnny
hi, quite new on the threads so apologies if i'm not 100% on protocol.
my trusty Logitech Z906 is now suffering the 'not powering on' issue. I've read through the previous threads on this, looked at all the repair videos etc.
problem is, i have no idea how to pull this apart properly, test the fuses, solder and replace the parts, and then put back together...
is there anyone who can help with this? of course happy to pay for parts, labor etc. would also like to watch and learn if that's an option?! :)
Logitech support is non-existent, and i've also taken to repairer at Sim Lim who would not help, so i need some professional expertise.
any help greatly appreciated.
86technie
Depending how old it is, usually is not the fuse or minor components.
But rather the circuit board that is faulty, even if you can fix it.
It is only a temporary solution, most repair shops that does radio/speaker
does not do PC speakers.
If for PC use, get a good 2.1 speaker.
If for TV use, get a good soundbar.
These retro 5.1 pc speaker doesn't last, I used to own Creative Gigaworks G500 which
unfortunately is the circuit board that died.
There are soundbar with 5 speaker configuration but these are not for use with PC.
dannnnnny
I got this far in separating the parts, but wasn't game to then separate the other power board. from what I could see though, no damage, but as said, i'm not an expert and wouldn't know which fuse is which.
agree, Logitech likely won't be on my purchase list again, however, this system is nearly 10 years old, with crisp amazing sound and has never missed a beat...until now.
if there's any way i can repair as opposed to replacing, or jumping ship to alternative i'm keen to explore. if it is the case of replacing some fuses, it's obviously a hell of a lot cheaper than purchasing new.
even someone getting a multi-meter on it to test would be helpful. yes, i'm that bad i don't even know how to do that properly :)
tsteo77
Hope that this can help you out > http://www.technofied.com/speaker-repair/
86technie
Fuse look like this, is not inside the circuit but at the power cord area.
Fuse purpose is to prevent any trip or short circuit which is also found inside power cables
as well.
However even if fuse blows the electronic still can power on which is why
don't believe what online says is fuse issue.
From my experience with my Creative is the power board as well as amp has failed.
FYI Logitech Z623/Z625/Z906 series have been discontinued not to mention these speakers
are very old design.
Concurrent best Logitech speaker is the new Logitech Z407.
I prefer this than the Logitech Z623/Z625 as the Logitech Z series the mid-range (Vocals etc.)
are very harsh and lacking despite strong bass.
Viper0402
Don't scare me, had my Z906 since March 2022.
Z906 has since been discontinued and NO announcement of a new 5.1 model replacement.
My previous Creative Megaworks THX550 repaired woofer once after 10yrs and lasted me close to 13yrs.
Phen8210
That's why i don't buy logitech speakers, its made for the partially deaf. Maybe ppl buy for the RGB.
tigerwoods
Check the manufactured date, if recent less than 3yrs it's still consider new then dont have to worry.
tigerwoods
Logitech Z606/7 5.1 is the only recent 5.1 speakers from them for now.
86technie
Is a old model most shops stop selling even Logitech official Lazada also don't have
any of the old Logitech Z speakers.
https://www.lazada.sg/shop-pc-soundbar/?logitech&from=wangpu
If you brought one recently, don't worry warranty they will honor you for 1 year.
86technie
Sadly this model I used to own, isn't a good speaker the bass is very off.
I return it back to the shop exchange for something else.
tigerwoods
What are the options now for 5.1 pc speakers?
Anyone using 5.1 tv soundbars for pc?
86technie
Sadly there are none, in my opinion a good 2.1 speaker will be more
than enough for PC.
PC 5.1 is not like Home theater 5.1, don't say sound quality.
The center and rear speaker rarely use unless you have a soundcard that can
output sound to all speakers like Creatie sound blaster
Which is why for PC 2.1 speaker will be more than enough.
However if you really want a good 5.1 speaker, can look for second hand Logitech Z506.
Despite the model is old but that is the only good 5.1 speaker in the past.
tigerwoods
than enough for PC.
Have been using 5.1 speakers for my pc for many years for gaming and movies, going back to 2.1 speakers is a downgrade for me.
Viper0402
than enough for PC.
That's why my Sound Blaster Z connect via Optical to have pure 5.1 awesome surround sound in games or movies, music, etc.
