Long Range WiFi for Camps
lailainoob
Has anyone thought of the above idea? It's not specifically against the rules and regulations of the camp.
I was thinking of installing a directional antenna towards the public and see if it's possible to pick up any unsecured WiFi and just piggyback on it.
Here's several reasons why I would like to do this, currently with my PES status and vocational training they allocate too much time for training and in the end we spend a large amount of time doing nothing as majority of us are fast learners. I would like to be more productive during this period of wasted time and have greater freedom to the internet as Telecom providers in Singapore charge quite a fair bit for Mobile Data.
j_t_fusion
unauthorised access to any wifi network, regardless of whether it is secured or unsecured is still illegal.
reddevil0728
Sorry I was referring to Wireless@SG, not unsecured WiFis.
Did you grow up in sg?
Also how you know
"It's not specifically against the rules and regulations of the camp." To install a directional antenna?
chehjin
unless you are streaming videos, the local mobile data is more than sufficient for "productive" usages.
lailainoob
I'm using Coursera while in camp, so indeed it is taking quite alot of mobile data.
Also how you know
Not for a very long time. I'm just asking if this is any way possible, you don't have to get one of those insanely large antennas, I'm talking more along the lines of Nanostation M or the Picostation by Ubiquiti Networks.
aLeX84
Hi TS, it's great that you've taken an interest in improving your knowledge while serving but you won't get any productive replies here since your question seems to be more tech-related and not as much of NS protocol.
You might want to explore alternatives like asking a friend/relative with a large data plan to sign up for a multi-SIM that you can share. I've kept my legacy 12GB singtel plan for 2 years now and have 3 devices that rely on it for data. If I knew someone personally in your situation I wouldn't mind sharing the 12GB and the cost of the multi-SIM together. If you can't manage something like this, you'd be better off doing your homework on other tech-related forums about the range of these antennas. You should probably do a scan on the signal strength of nearby hotspots and the reliability of the power supply in your camp as well.
Oh and always remember SAF's 8th (or 9th?) core value - Do anything you want, just don't get caught ;)
ryan_ltw
just do it, but don't get caught,forget about asking for permission, it will always be "NO"
reddevil0728
so technically u actually do not know whether it's not against the rules and regulations, but because the gadget you want to use is small, you are planning to use it secretly?
reddevil0728
Somehow I read it more as NS protocol related than tech.
chehjin
well, for coursera, you can download the videos easily before hand and you don't have to rely on internet.
long range wireless@sg? i don't think can stream coursera smoothly anyway.
and your point about it not being against rules and regulation does not hold water. your device will have USB and LAN port, a small processor and it has communications capability. if your unit anal, they can send you for SIB investigation very easily.
2nd, the time you plan to use is meant for training, yes, u can be smart, blah blah, use less time, bottom line, this time belongs to the unit. you do anything else, be it legal to the confines of SAF, you are still wrong, because you are not following orders by doing your training.
look, i'm not here to debate with you, its your life, do whatever you want. but if i'm you, I will try my best to achieve my aims more descreetly.
hawkgod
i just install mobile router in my bunk.
uses a sim card router.. MP came and check also no comment. say our bunk like entertainment room... got TV got DVD player got PS2 got WIFI and lots of food
reddevil0728
Posting it here no longer discreet liao
chehjin
your unit ≠ his unit
but your unit welfare sia. =:p
