Loud 212x cpu fan sound...
jianrong
Hi,
This is a new rig ->
Notice 212x fan sound is loud when it is idle on desktop.
Is this normal?
alvintan89
Try to oil the fan bearing first and observe before you change. Save money.
trento
u can set yr fan speed to spin at certain speeds thru bios. it will spin according to cpu temps. so low temps, then slower speed so less noisy. or just get quiet fans, some good ones are Noctua, Corsair SP120 PWM, Thermaltake Ring led.
jianrong
Very new few days old.
Hmn. Had 5 fans blowing plus 212x. And gpu got 2 built in fan too.
jianrong
It doesnt seem to be 212x fan speed. I had 4 more led fan. (1 of them paste it with scotch tape as no screw for that spot)...
