Low Power Gaming Rig
sunburn0000
Hey all,
Im thinking of building a low power consumption gaming rig to run games like starcraft 3, simcity 2013, etc and be suitable for future upcoming games in full graphic settings.. budget below $3500.. can anyone offer some suggestions on how to build?
my room is not airconditioned, so do i need a better cooling system, as it sometimes gets real hot when i am playing in the day....
Emerson92
when ur budget , im sure many bro in the forum can help you out ! too bad im not a pro in this field ! haha
nippp0n
Do you need os, monitor, keyboard, mouse and wifi adapter?
Do you intend to overclock?
sunburn0000
only require OS! Dont know how to overclock -- so i guess no?
ya i prob need a list to bring down to SLS.........
beng035
what that budget, many bros here would like to share some of that with them
JasK
Hey all,
See pm, some ideas and discussion for u
llhuskyll
Hey all,
wow bro few months back i buy my new rig at 3.2k and its over over over over over kill LOL..
$1400-$1800 with do you good :)
JasK
ya overkill indeed, yours is OP. even mine own rig i also find abit OP, but TS may just want to spent and want the best but if you get the best, there will be not much of power consumption savings
llhuskyll
OP~~ haha
2k should do it with
AMD 8350
asus HD7970
H100i
16GB ram
crosair R400
4x120SP High Static fans :) PUSH PULL~
WD Black 1TB
:s13::s13:
sunburn0000
The integrated graphics on Intel core i3 3220T with HD graphics seems to effectively lower power consumption. Anyone knows if I can still run games like simcity 2013 starcraft or diablo with mid or full graphics?
nippp0n
Given your budget, why will you want to use integrated gpu to play your games? You should be looking at discrete gpu like 7970, Titan or GTX 670/680 to allow you to play most games at high settings smoothly.
JasK
OP~~ haha
AMD 8350
asus HD7970
H100i
16GB ram
crosair R400
WD Black 1TB
:s13::s13:
u bluff, you had a different spec before this post, at least i knew and saw a i7-3970 or 3990 pc spec...
llhuskyll
JasK
Not good enough, the links missed out some details where certain games need a dedicated card. this processor is fine but can consider 7790 85w tpd at lower tier, gtx 670 170w at higher tier, and the titan is 250w, best if u want the best, heh
deathsaurerxxx
Don't understand why u're so obsessed with low power consumption ? :s11: Usually in order to play a game at high setting smoothly, the higher the frame rate the better and that usually means better gfx card and the better the card translate to higher power consumption. Same thing applies to the cpu (some games are more cpu dependent like Starcraft).
But than since u got so much moolah u might as well get an Aftershock laptop since when all's said and done a laptop should have a lower power consumption than any diy desktop.
http://www.aftershockpc.com/
sunburn0000
Long story short I stay in an old house and I have to pull the power into my room. Its weak and prone to trips.
Forcecore
In that case, you should consider getting 1 UPS(Uninterruptible power supply), just in case where there are power trips you still have power to your PC and do your last min documents saved etc..
coyote
Very simple.
$1000 for a single unit aircon for your room.
$2500 for a kick ass gaming computer.
Problem solved. :D
Hey all,
