Cokester
Check your email, they will send 1 copy with password protect using ur NRIC.
If not use M1 app and go to " more " (bottom right) -> " My M1 Service " -> " Plan contact" -> " Contract " to view it.
Nakedtoes
I think recently they onboarded too many users so congestion exists, it only happen this few weeks, youtube will get stuck or buffer but mostly go away after a while. Fully wired and router is a UDM SE so unlikely to be internal network issue.
Dun think so.. I using simba 2.5g.. Recently also find YouTube abit lagging during night time.
Nakedtoes
Wow.. Just check my place is eligible... Is the Asus 92u better or tplink 805?
Nakedtoes
For be805 users, new firmware 1.22 is out. Is slighlty more stable than 1.20 but sometimes facebook youtube and insta and whatsapp still buffers. And have to manually off and on phone wifi to get the speed back to normal.
So how is BE805 now? My previous tplink router CaN vomit blood sia... But I see ppl who get Asus Be92 also vomit blood lol.. Likely is because wifi 7 not stable yet
calkel20
Upgraded to M1 6gbps with BE805 router.
But then speedtest returns only 90+mbps. Is that normal?
Jun Jun
Guys, I am still testing beta firmware version 3 based on 1.2.2. Dont worry. Things will be resolved. Now it is getting better.
Booomz
BE92U got Merlin wrt firmware out alr, so far seems like they fixed most of the issues.
I personally will pick Asus anyday, but if you need the wifi speed then maybe be805 better.
It depends on your needs, as a single router, I will choose Archer BE805 over Asus RT-BE92U (or even single Asus ZenWiFi BT10). The HW spec and wireless spec of Archer BE805 are much better that RT-BE92U.
Asus is pretty bad in terms of using lower end CPU in ZenWiFi BT10 and RT-BE92U.
And that is what I did as well, I bought the Archer BE805 from an M1 user at S$300 early this year.
On the other hand, if you want to go with a mesh solution, TP-Link EasyMesh is really not mature yet. Top up for two ZenWiFi BT10 and that will be better than two Archer BE805.
Nakedtoes
Thx alot...... Cause the new 6ghz range is shorter... Getting Ai mesh is a good solution. Somemore mine rooms are wired. Bt10 MLO stable? Any b10 user CAN feedbavk?
Jun Jun
6ghz is shorter range cant be help. The only issues are network stability and mlo not supported properly e.g.2.4+5+6 and the back haul easymesh not supporting some of the main router's features
