M1 Fibre Deals
joesph
https://www.whizcomms.com.sg/promotions/ceeshow2019/
my M1 1gbps expiring this weekend.
Since I am usually away from home half the time, seldom use 500mb data sim card and home fixed voice, my options for new contract:
M1 500mbps: $29/mth
Whizzcomm 500mbps: $26/mth
Whizzcomm 1gbps: $32/mth.
Can use back the same M1 router, don't need new one.
Anyone with experience in changing ISP? Is it very disruptive with downtime?
use the other ONT port
Sent from Samsung SM-G975F using GAGT
xonix
On Singtel now and considering moving when contract ends next month. Should I go with M1 or StarHub? My mobile plans are With StarHub but no intention to have StarHub tv.
Are you planning to move your mobile plans also ? If yes, then see which telco give better deals for fibre + mobile signups.
xonix
M1 500mbps: $29/mth
If you want to minimize disruption, the safest way is to overlap the end and start of both services.
ceestudent
M1 500mbps: $29/mth
Same as you, considering for whizzcom or m1 but decided to recontract m1 to enjoy the multi service saver for my mobile line. The saving is more than 3$ per month.
saintgtril
I am an existing M1 user. If switch to whizzcom, can still use the same M1 router? Thanks!
Yod4
Nah, I’ll stick with StarHub for my mobile plans. My company has pretty good cis deals with StarHub.
titank
So now we do a recontract with M1 1G Plan at PC Show or at the shop would there be any difference?
winningeleven
It seem m1 is not taking part in the PC show. The offer they have right now is the same as cee. I just did my recontract online. Save the hassle to go to shop. The Goggle mini and the router upgrade will send thru popstation which I have opted to. (can choose collect from shop and delivery to home(no available anymore)
