Mac mini and external display issue
Timbre70
I have a Mac mini 2012 connected to external display. It has been functioning very well until recently.
The display (ViewSonic) monitor will blank out suddenly every now and then (about 15-30 mins interval) despite I am actively still using the computer.
I need to turn off the display and wait for a minute to turn it on again.
What is the likely cause?
Thanks in advance for your help.
Timbre70
Thanks for your reply.
Unfortunately, I don't have another spare monitor to try out. I tried the AHT, given clear "bill of health". Lol...
I will try to dismantle every connections and rewire back to see what happen again...
Timbre70
I unplug and plug back all points, straightened all wires (instead of bundling the excess up). It seems to "improve" a bit. It does not turn off as frequently as before, Then again, it is less predictable compared last time, making trouble-shooting even more difficult.
R4YM0ND
this seem to be a problem for os x on certain monitors. do you have bootcamp? does it happen in windows?
szeli
without another monitor to troubleshoot very hard to isolate e issue...
Timbre70
Quick update:
Quite sure now it's a display issue rather than Mac mini issue as the display randomly shuts off by itself, i.e. no lighted ON/OFF indicator, power cut off. Needs to turn off main switch, wait for >20 seconds and turn on again.
Experimented by turning on aircon and putting a USB fan behind the monitor to cool it down. Seems to work well.
Probably the internal fan (if there's one inside???) is fried.
jeffrey745
Quick update:
To b sure, bring ur mac mini to an apple shop to try on the cinema display?
Timbre70
Conspermed monitor fault. Totally gone case now. Bought a new DELL P2014H. Couldn't been happier.
