Macbook 12 spacebar problem
TechNuB
the left side of the spacebar is working fine.
but the right side does not respond. seems to be stuck or damaged.
Called Alab they say 130bux for diagnostics alone
Free key cap replacement if keycap is the issue
but if is the keyboard issue need >500 bux to replace the entire keyboard.
Any bros got similar issue?
how did you resolve?
is there some cheaper alternatives??
dont make sense to spend so much for a spacebar leh.
Thanks in advance!
zitseng
Thanks in advance!
It's out of warranty?
I've a slightly problematic key too. Sent to QCD... they're taking a very, very, long time to fix.
TechNuB
yep its out of warranty.
how much are they charging you at QCD??
renfred89
Yeah, but I don't think anyone will repair just a key as well. Usually it's the whole keyboard that is replaced.
I know of a trick using wd40 to make keyboards work, but if it's a stuck key or a broken key, no miracle..
Sound like an expensive repair bill if done at Apple.
As per article, even Apple does not replace the key but the entire set due to the fragility of the new keyboard mechanism
http://bgr.com/2017/10/19/macbook-pro-2017-keyboard-not-working/
TechNuB
Apple store lead time is a week, but also depends on the severity of repair..
wah GG No spacebar the macbook also half gone.
mayb can reprogram one of the shift keys to become a space bar???
