MacBook Pro Battery
falcon2000
Hi all
Could anyones recommend place for replacing MacBook Pro battery ?
Does the battery quality would be same as Apple store ?
Thank
Snoweagle
Hi all
Thank
Especially when it comes to batteries, settle for nothing less than from Apple Store.
szeli
which model? older models can diy get from shopee/lazada
freebies4lyfe
i think best to buy directly from the apple store if you want your battery to last. mine last for 6 years alr, battery from apple store.
rowrowroyce
I am looking around online and for battery cost, its only around $100-150 bro? Thanks for the tip!
If no warranty can consider this
https://www.ifixit.com/Store/Parts
Posted from PCWX using Rem mm is best waifu
szeli
just replaced my 2012 MBA battery from Shopee $45.
