Macbook Pro problems.
HalimHidayat
Macbook Pro 13 inch (Early 2011)
2.3 gHz Intel iCore5
8 GB 1333 MHz DDR3
I have some softwares such as office, PS5 and Autocad which i still need and i wanted to reboot my macbook. Any idea if its still possible for me to retain the softwares? Cant remember all those CD keys tho.
reasons why i chose this option is because my macbook is getting laggy and hot. any idea how to repair loose hinges and lost rubber bottom grips. hehe.
the top question is more important one tho
cheers!
asriznet
8 GB 1333 MHz DDR3
cheers!
If you planning to erase and install and manually restore your data then you may need the installers for some apps. Apps ending with .app which don't require any user settings are fine, you can just copy it elsewhere and place it back after E&I. I would advice you to run a time machine backup first. Apps like Microsoft Office, Adobe suite requires the installer and product key for reinstallation and cannot use the copy paste method.
Refer to www.ifixit.com for hardware repair guides
You can order DIY replacement kit for MacBook Pro bottom case rubber feet at around $20.
MacBook Pro: Bottom case foot replacement DIY instructions - Apple Support
There are other cheaper options but I doubt the quality of it as some are just stick on with double sided tape.
The kit provides 2 pieces of rubber foot, the kit and instructions or you can refer to above article for steps.
