Magnetic charging cable with Type C plug
Habrosus
Was looking out for something similar when I first got my A7 2017, but now decided to just use an adapter (microUSB > Type C) so that I can continue to use my many existing magnetic cables that I've lying around. =:p
Now to wait until that same brand comes up with the Type C magnetic adapter. :)
Habrosus
Where you got your magnetic cable?
Qoo10, Baseus brand.
I've used another brand before (green box) but the adapter was very difficult to remove (had to use the plastic remover provided) when the need arise.
stylechap
Have you considered you'll somehow shortcircuit and spoil the usb port when you're not charging?
jtjt00
With the plug in port, you need to take care not to place near metal object.
neverend1
I got my magnetic cable from ckrow. It isn't type C but the charging speed is pretty fast. and i got 1 year of warranty. so decided to give it a try. been using for a month, so far so good.
neverend1
i checked the box, it only says fast charging but not qualcomm quick charge certified. haha. it certainly charge faster than my original charger.
