Magnetic sunshade
bh10101
also.. i will never buy BLACK car again.
after switching to white car, the difference is really stark.
white car so much cooler even if parked under the hot sun.
few days later.. your white car turn black gray loh :s13::s13:
aall88
I bought from them back in Feb for my car. Everything was smooth (from payment till delivery). The sunshades are also of good quality, quite useful in our blistering hot climate.
Apologies for reviving old thread - anyone else got any reviews or comments? It seems like more and more of these "customised" magnetic sunshades nowadays - hard to figure out which is good. In fact, is magnetic even necessary? If the fit is correct, it should just stick into the window nicely right
bwaysaikryptonite
all these are just cheap blockage more of privacy la not block uv or sunlight lol...$40 can’t block uv.
want cheaper solution go get those dotted window sun shade mesh self stick type and stick to chiur window partially...juz cut same size as these magnetic shade or whole side window and chiu will never have to remove them unless inspection time then chiu juz remove it and put it back...it’s self adhesive and no need to put what clip or remove and put back shade...can wind down window without any blockage too
Nurse.Vijay
Good for those who want privacy and not attract white ants. But if you can afford just do blackout solar film then replace when needed. Block heat and get more privacy.
wiwi86
magnetic is for ease of putting it up and taking it down whenever u need. it just snaps into place. and being magnetic, i feel its more convenient than the traditional suction cup type..
aall88
Thanks for the responses everyone! May I ask what's the issue with "white ants"...???
myviowner
got anyone try those silver shiny thing they put at dashboard before they exit the open air carpark?
I tried it last time, its damn cheap for DIY solution
but you must remember to put it. lol if not just get a proper magnetic sunscreen.
Black coloured are like this. What sun shade lah, 99.99 UV ray light reflection on their tinted windows...BS lah. Still has hot :s13::s13:
Mclairs83
i don't really care. just bought a set from qoo10 2yrs back.. still working. it doesn't even require any clip.
and good thing is night time, people can't peep in no matter wad.
hawthorne
Have been using it for the longest time. It's useful when u need to wind down your window on the daily basis cos it does not interfer with your window
Sent from 雪花飘飘北风啸啸, 天地一片苍茫
一剪寒梅, 傲立雪中, 只为伊人飘香 using GAGT
KoolBlue
I'm deciding between Dr. Shadez or Carwerkz for my new car. Anyone using these?
Dr. Shadez $119
Carwerz $75
Any difference between them?
Currently using Groovy but don't think can find in SG now.
Astro
carwerz good enough. personally feels it fit just nice. except to remove one side of it when at Woodlands Customs so ICA officers can check up faces n passports
bwaysaikryptonite
teh real ones from Australia or US costs a lot more and teh quality ish different and material also UV certified etc..teh mesh chiu touch and teh intensity of teh “pores” chiu also can see...those $40 magnetic shades ish just buy for fun more of privacy notch blocking sun uv
zXioNGz
Normally I buy from Britz sunshade, their one strong magnet but problem I faced that these shades block half of the driver’s side mirror view. At times during night driving I find it too dark and block the side view for driver side when I’m trying to filter to the right at higher speed on expressway. Just remember to be careful
EJB
I bought from groovy, ordered through the msia site, it was backordered, took a few weeks to arrive, but happy man.
Conan1986
actually what’s the difference between these ”branded” shades vs those Lazada ones ah?
EJB
The groovy ones were made to measure, meaning they really measure and ensure the sides/edges are correct in size and the magnets are properly covered etc. They cover every window for mine, the OEM ones only 4 pcs. Mine from groovy is 6 pieces, with optional rear piece +1.
The quality of the shades also seems to be better opposed to the cheaper ones. The cheaper ones just seems like sun block than shades to me. Just me. My agent offered me hers, but I told her I'm not keen and I only want groovy. She rebate me in cash instead. My groovy ones were way more exp.
myviowner
Big brother is indeed big brother..... i need to learnt this... Thanks Big brother @EJB
veryhonestguy
Been using it for months. So far, so good. People can't see into the car cos of the tint.
why u dont let ppl like me to see inside your car, i always like to see inside ppl car when on the road
