[MAJOR PROBLEM] FILES ACCIDENTALLY DELETED FROM SD CARD
Beateratorrr
Hi all,
I require some help from all the techies here.
I had accidentally deleted all of my photos and videos on my SD card;
I was able to retrieve them back using a software.
However, most of the files retrieved are corrupted. Is there anyway I can repair the files? They are in MOV. and JPEG. format.
Any help?
xtramadness
1) the files are really corrupted
2) the software didnt do a good job, get another software
3) Go to a professional data recovery center
What software u use?
mosmos
High Honorary Member
did you keep on taking photos after accidental delete~? It may over write some files~
jeff79
First thing to do is push the write protect lever on the side of the card to lock it from overwriting the deleted files.
Part of files got overwritten will corrupt the file.
Audiology93
Hi all,
Any help?
Get professional data recovery help like what xtramadness bro said.
dexmus
sounds bad. i guess u really need to find a good data recovery program to help u. but for now u should not be using the sd card for now. hope u will be able to get back all ur data. gd luck!
Gaiason
try with another "better" recovery software... else if it is really impt data.. seek professional help. :vijayadmin::vijayadmin:
lenseview
Dont try to do anything by yourself anymore. Just seek professional help.
yusoffb01
use recuva. if corrupted means u continue to use after delete, so files got overwritten. in that case cmi liao
mocax
data recovery services usually quite expensive... :(
unless you got data that's critical to your company... :(
