Making my Pc need help
Potatoman50
Hey guys some of u all may have seen my post but i discarded that one so this is the new one. i would like u people out there to rate my specs and give me opinions on how what can be further improved my budget is $1,600. The following parts name:
-Motherboard=Asus H97 Plus(4690)
-Internal HDD=WD Green 5400 rpm 3TB
-Solid State Drive=Plextor M6S 128GB SSD
-Memory DDR3 Kit=G-Skill RipJawX 1866MHzCL9
-PCI Express VGA Card=Asus GTX750Ti 2GB OC DDR5
-ATX CASING=CoolerMaster N500w/windows USB3.0 ATX
-ATX Power Supply= CoolerMaster Thunder 600W PSU
-Internal SATA DvD/DvD Writer=Asus DRW-24D3ST 24X DvDRW SATA
The above are the parts.
I would like to upgrade the casing fans,the casing can onli fit 2 fans. The list of them is the following:
-Aerocool Shark Fan Devil 12cm
-Corsair AF120 Performance Edt (1650rpm) 30d
-Corsair SP120 Performance Edt (2350rpm) 35d
-Corsair SP120 Quiet Edt (1450rpm) 23dba
-Corsair AF120 Quiet Edt (1100rpm) 21dba
-Corsair AF140 Performance Edt (1150rpm) 24d
-Thermaltake Luna 12 (Blue/Red) LED Fan
-Xigmatek XLF-F 1255 12cm White Led Fan
-Xigmatek XLF-F1253 / 1254 12cm White LED Fan
-Xigmatek XLF-F1453/1454 14cm White LED Fan
-Xigmatek CLF-1252 Crystal System Fan 12cm.20
-Xigmatek CLF-1452 Crystal System Fan 14cm.30
-Enermax T.B Silence / Apollish 12cm LED Fan
-Enermax TB Vegas 12cm LED Fan
-CM R4-SPS-20 Standard Fan 80mm (CM690)
-CM R4-L2R-20 90CFM/19 dB-A 12cm LED Fan
-CMaster BladeMaster 120mm R4-BMBS-20PK Fan
-CoolerMaster CM Essential 140mm 1000rpm Fan.
-CoolerMaster XtraFlo BladeMaster 120mm Fan
-CoolerMaster JetFlo 120 Red/Blue/White 12cm.
-CoolerMaster MegaFlow 200 20cm Fan Black.
The above are the fans, so any suggested one? I am looking for those can cool the cpu quite well.
Feel Free to give me suggestion on wat to updrade as long as everything keeps in $1,600 i am happy:) BTW anyone knows where to buy cheap and good DELL moninter? I heard theat there is a place called TP(not temasak polytecnic) but idk the full name if anyones know Reply.THX
The parts list can be found under the price list tab,The heading is PC components, then click on Fuwell International Pte Ltd
Thank you for taking ur time for reading it.
Jian19
Wads the usage of the pc ? If u game wad type of games u play ?
shadow84
1. Drop the mobo + cpu to MSI B85M G43 / MSI B85 Gaming + i5-4460.
2. Get Toshiba 3TB 7200rpm, it has better speeds.
3. No need for 1866mhz rams bah, and i presume its 2x 4gb?
4. CM N500 can support up to 9 fans, including the given 2 fans...top 2, front 2, rear 1, side 2, bottom 1, hdd cage towards gpu 1.
5.Get a better psu, like superflower hx500w/600W, seasonic G550w, S12G 550w
6. Ur cpu cant OC at all, it wun reach super high temps... Intel stock cooler good enough le. Just get a decent cpu cooler if u dun like stock cooler. Deepcool gamamxx 200/300 will do.
TP = tradepac, lvl 5 back alley, run by ah nehs. Bargain and ownself DIY, or brign to #02-32 and ask nigel for help. Dun let them assemble for u.
