唐一 @Makkiiil - 5月8日,越南嘉莱省包干乡人民委员会证实,该地区发生一起劳动事故,一名男性工人在工作中不幸被卷入橡胶混炼机,不幸身亡
BBClone
Wow what is that white zhup that squirted out? Was expecting blood in the video, but only seen in the photo.
Don’t understand why the worker didn’t just let go of the shovel, maybe he panicked and when his leg was caught, it was too late.
BBClone
Most likely brain matter being forcibly extruded out of a small orifice.
I’ve seen it in one other accident video involving a mold machine. Same consistency.
Isn’t that a bit excessive compared to the volume of CSF/brain matter?
DragonFire
Hard to say. If most were extruded at high pressure, it could account for that much.
Blood doesn’t squirt because it isn’t trapped. It can migrate to other tissue under pressure. The brain case though is sealed and there is no where else for the contents to go when the container is deformed under pressure. At least until a crack appears. You could probably compare it to a sealed can of paint being squashed. The effect is similar.
Yuba84
Evil and should not happen: if I were Vietnamese ops director, Actually I have a way to separate the plastics and mash to use as recycle material. Just soak the mash in water and the different materials will separate and float at different levels. Usually the latex will rise till top? And can be skimmed off. Then put in flat pan to dry under sun can liao. To reuse in low percentage with fresh latex in new batch.
d3n
oh my......
bad work safety education at this factory
Ubi-Warrior
This factory has zero safety awareness.
How can the worker work INSIDE the feed hopper with a LIVE rotary valve turning below it?
Just waiting for accident to happen.
Safety is expensive.
Thats what those who want no regulations say.
ChuppaChups
Got any expert here can draw a diagram of the machine and show how it is supposed to work? How did the body get minced up on the last screen capture? I thought whole body got into the rubber mixture.
N4E.SI
Why I seem to hear female screaming
Is other colleagues see aldy scream or that is his own scream?
randyap
I suspect he slipping and lost balance and need to find a pivot back to balance. But no railings or anything, and the only pivot is the rod which leads him further towards the death zone.
randyap
images
Not sure if it is this.
Multiversal
This means that the machine was badly designed with no safety features.
apking555
Brutal. Slowest inevitable machine casualty I’ve seen. Guy felt every chunk chewed off. The mechanism prevents catastrophic blood loss and consequently keeps you alive much longer than you’d want.
Most other machine fatalities are quick. A brief spin or squeeze and you expire. This one is a slow munching. Inch by inch by a masticating screw.
Is that why he can still continue screaming for help?
