Malaysia and Indonesia DTV reception
hanrose
Malaysia channels
Hi guys,
May i know what antenna should i buy to be able to watch malaysia channels.
Appreciate if you can guide me the procedure. I just got the free digital antenna
from best denki but after scanning, my TV1 is gone although got all the CH5,Suria,CH8,Ch newsasia, Vasantham in digital. I am more incline in watching mat yoyo stations. Thank you.
petetherock
Moderator
Moderator
Hi guys,
Are you living in an area which can receive it ??
hanrose
I am living at Jurong West St 65, 2nd floor. Just got the free HD antenna from Best Denki and when i scan only the free to air HD S'pore CH appeared. No msia channels. What can i do to receive the M'sia ch or is there any specific indoor antenna I should purchase? Thanks
amazingone
Don't think your location can receive Malaysian digital channels well.
petetherock
Moderator
Moderator
Generally residents in the North MAY be able to get M'sian channels, and those in the South MAY be able to get Indo channels.
The key word being MAY.
Your exact location, the height, all kinds of things matter. Short of moving.. if you can't, well, you can't.
cscs3
Has to move house!
Shion
Senior Mentor
2nd floor difficult
AS1
Got any box that can get both RTM and digital channels? NSM one cannot get RTM although also using antennae?
Kiwi8
Deluxe Member
I think ultimately it still depends on the location and the antenna u using lor. Any set top box should be able to tune to the channels as long as the signal is strong.
AS1
It’s not the set top box that’s the issue. Location is.
I see. Will stronger antenna help? Because since older antennae aerial can receive RTM and etc analog channels, odd that newer one cannot.
Kiwi8
Deluxe Member
Hard to say exactly what happened.
It could well be that the analog RTM signal was broadcast using more power as compared to the digital RTM signal, which may be broadcast using less power since digital signals are more robust to interference.
In any case, what antenna are u using now? A passive one?
I understand that those people who had the IMDA $100 voucher used it to redeem powerful Funke antenna, so u might want to try this option.
