Man dies in Thailand after vape explodes in his face, causing severe mouth & chest injuries
win_man
Another Thailand rubbish news. They think readers are dumb. If you say suffer burns all that i believe.
DragonFire
How it explode?
Bad battery. Operating vapes really stress out a battery. You're heating a rhigh resistance wire red hot by dead shorting a lithium battery.
If the battery is poor quality or damaged, this is a trigger scenario for it to pop dramatically.
DragonFire
Rubbish news. They think readers are dumb. If you say suffer burns all that i believe.
There are plenty of published cases worldwide tho. Mobile phones with similar power supplies have killed by proximity explosion too.
You think this might be a government op ed to suppress vape culture?
oddbasket
Occurence too low, hope there can be a larger sample size to deter people from vaping :cry:
hip_programs
The batteries used in vapes are lithium polymer 18650 cells or gel packs. Vapes require unregulated cells because of the immense power draw, and lower quality or damaged cells have the potential to pop.
This fellow probably inhaled superheated gas.
does the current draw exceed portable fans?
many ppl use unbranded fans.
DragonFire
Yes way more.
Generally speaking for peak load.
Vape = Portable "hobbyist" cutting laser > High powered torchlight > Portable fan
The newly trending portable fans are just high RPM brushless motors you might find on a power tool or vaccum cleaner repackaged to move air. The load profile is docile.
DragonFire
Will it happen in spore?
Many probably still vaping secretly.
Probablity says "eventually".
Same probability also says aliens will eventually come.
The quality of vape BMS has probably gone up over time since we don't hear of them popping like celebratory firecrackers so often.
But winning the lottery is a thing.
Lchlch
Just like pmd, all chiong types...
DragonFire
PMD motors are another super high peak load scenario. Usually it is the ESC that lets go under load tho. Switching peak loads and handling all that back EMF is nuts.
The batteries more likely to pop during charging or after physical insult.
It is not unusual for a small battery pack to supply 100 to 200 amps in acceleration phase for a high performance PMD.
Lchlch
Till now government still monitoring on pmd?
Still don't mandate ban.
