Mastercard tap in TransitLink
jaloon
So without reg or doing anything, i now can just use apple pay with MasterCard to tap at the gantry? Or do i need to reg.
Using contactless cc, with cepas. But apple pay need go GTM do setting?
Apple Pay with Mastercard can just tap. Contactless CC with cepas must do something at ticketing machine.
lamEduDe
I receive a sms from UOB. it says only those with the sms can participate in the testing
when I want to add in my UOB one card, it say this card is not available for pilot testing....zzzzz
do u have any other card already registered on simplygo? if yes try removing all other cards and then register your uob one card. i was in same situation and managed to add after removing all other cards
revhappy
CIMB might not have promo. They already give 10% rebate which is better than those short term ones with conditions.
The 10% rebate doesnt include this simplygo
Travel spending shall include all local and overseas transactions made at Airlines, Hotels
(excluding transactions made for wedding banquets), Travel Agencies, Cruise Lines and
Railways only. This does not include transactions with descriptions containing “Ez Link”,
“Transit” and “Transitlink”.
revhappy
Should get 10%, been getting 10% for ABT
Hmm, strange, then what does exclude 'Transitlink' mean?
Also notice the usage of the word 'only'
Railways only
vsvs24
CIMB Plantitium master confirm can get 10% rebate.
Transport and Petrol spending shall include all local and overseas transactions made in
transportations in the form of bus, train, private hires, taxicabs and limousines, ferries as well
as transactions made at petrol kiosks. This does not include transactions with descriptions
containing “Ez Link”, “Transit” and “Transitlink”
Stamp and chop. I have been getting it for past few mths. It used to be called ABT. Description shown on CC statement is "Bus/MRT".
curo
Pls be reminded that if u use your card to tap it then you have to use your card to tap out. If you used your mobile phone to take in then use your mobile phone to tap out.
If not they will have missing entry or exit and the system will charge you $2 on your card and $2 on your mobile.
It happened to me and I jus realized when I check using the simplygo apps
Trazora
Yes. Card in mobile and physical card have different numbers
shengliang1981
Does the 10% rebate for SimplyGo requires minimum spending of $600 as well?
shengliang1981
If I use Samsung Pay to tap, but my phone also has NFC SIM inside, what will happen? Will it deduct from both sources?
hyperbole
I just kena this missing entry even though I clearly tapped in and out with same device
ixoral
Hi all, sorry if this has been discussed before.
My SCB unlimited has an EZ-Link function. So when I tap it, it says low value - of cos since I didn’t top up the ezlink wallet there. So how do I get the bus/mrt terminal to recognize I want to use the CC function to tap instead?
assiak71
Register your cc in simplygo
Go to General Ticketing Machine (GTM)
