Mastercard tap in TransitLink
addict951
High Honorary Member
Info for CIMB cardholders:
I registered my card ytd only. Din receive any email or confirmation. Just nao I tried tapping the card at mrt gantry, immediately showed: "BANK CARD USAGE".
TiOnGSquare
hi guys i have problem activating my card at the GTM
im using the scb unlimited cash card, registered at abt site, received confirmation email, went to GTM but when i place on the system, it doesnt show any option for me to switch to Use Back, instead the normal selection screen with the options "Add Value" "Activate Ez Reload" "Check Card" is shown. i tried to tap into mrt, it shows "insufficient value".
Anyone have similar prob as me? Thanks!
wtf the abt helpline cant get thru one arggg
revhappy
I have started using my CIMB platinum MasterCard since today. Works fine, except for showing the fare. When I keep it in my wallet and tap, it takes like couple of secs extra for the tap to register compared to Ezlink. Ezlink is much quicker. If there was no promotion I would prefer Ezlink with Citi SMRT than this ABT.
Sent from Xiaomi REDMI NOTE 2 using GAGT
jtv_tm
Weird I can't get my Citibank Rewards Card or WWMC registered for ABT. grrr
haydentan
Today I started using my card and realised that when I tapped in the message is 'bank card used' but it didn't state the price of the journey when I tap out. Isit supposed to be like that
You can check your usage n fares with the link sent in the email from transitlink to activate your card with login and password. Trip usages will be updated a day later. More convenient and you can check them on the move. Of course if there is any discrepancy u can click one of the tabs to report.
hyperbole
not all trips are reflected a day later. my bus trips from 2 days ago still not reflected.
addict951
Received my new SCB MAN card last nite, activated and just now tap at MRT gantry then immediately "BANK CARD USAGE"! $30 here I come!!!
redglue23
Anyone try on bus 170 to and fro jb? From Kranji to sg custom is considered 1 trip, then board the same bus after sg customs to Malaysia customs is considered 2nd trip ah? Any problems boarding 170 on jb side to return to sg?
Whisper
I accidentally registered for my debit card when i was withdrawing money. Then received SMS to ask me tap my card at GTM for activation. But i do not want to activate. That means i cannot tap my card at GTM for top up coz once tap will be activated for MasterCard Tap? :(
Trazora
Why not remove the card from the transitlink abt?
w4rdsg
Dun worry, the GTM will ask you if you want to use bank card or EZ-Link for travel
Whisper
Need to create account first? I don't have account..I just suddenly received SMS from DBS (i accidentally registered when withdraw money) and CIMB asking me to activate at GTM.
