Mate 80 series
stillgottheblues
Mate series got not much improvement over older Huawei. The camera is the only thing that you can see. The rest is minor improvements not see-able.
DeepseaG1523
I recently visited Huawei store in Shanghai, I must say very impressive when I go hands on with the mate 80 series especially the mate 80 pro max, very premium and the camera is really good!
The shop was super crowded just like apple store.
Didn't take any pictures of the mate 80 series as my attention was drawn away by the matebook fold. Truly remarkable hardware and software from Huawei!
¥24k for 32GB / 1TB 😅
chari-men
This looks good man...
T_JU_H
use gbox?
what about if u want install other region app by using VPN
Though I've never tried it, I suspect that things should work alright if you install microG Companion and microG Services from Huawei's AppGallery. Once done, there's no need to use GBox for GMS dependent apps.
At Huawei in Westgate, I saw that these microG apps were pre-installed in their display Huawei Mate 80 Pro.
There are of course also VPNs available from AppGallery, but perhaps they are not the ones you prefer.
stillgottheblues
Can use micro G with Aurora store if you don't want to use gbox. Micro G is the basis of all Android ASOP to connect to.GMS.
What is 5A?
5A is 5.5G in China.
Not exactly. It is not 5G Advanced, it is not 5G SA.
It is Huawei China specific.
https://consumer.huawei.com/cn/support/content/zh-cn16081318/
1、什么是5A?为什么信号栏会显示5A标识?
5A代表华为终端先进的通信技术,可以为您带来更快接入、更快网速、更低时延、更稳定连接的综合通信体验。
2、5A是不是一种网络制式?
5A不是一种网络制式,是指5A级的优质网络体验,它代表华为终端先进的通信技术,可以为您带来更快接入、更快网速、更低时延、更稳定连接的综合通信体验。
3、5A和5G-A(5GA)的区别是什么?5A是不是5G?5A是5G-A(5GA)吗?5A是不是5.5G?
5A不等同于5G-A(5GA),也不等同于5.5G。
5A是指5A级的优质网络体验,代表华为终端先进的通信技术,可以为用户带来更快接入、更快网速、更低时延、更稳定连接的综合通信体验。
5G是第5代通信技术,是一种网络制式。
5G-A(5GA)/5.5G是5G的演进版本。
OutBreak
2、5A是不是一种网络制式?
5G是第5代通信技术,是一种网络制式。
Too bad not available in SG.
Mate 80 Pro Max 风驰版 with a built-in fan
Chinese reviewer
UK reviewer's quick overview video (this video also includes a quick overview of the Enjoy 90 Pro Max, a budget phone using HarmonyOS 6.0 and Kirin 8000 series SOC).
T_JU_H
Unfortunately, Huawei Singapore, when asked, could not give any information about when the Mate 80 Pro Max will be available here.
I've read that the Enjoy 90 Pro Max, with 8500mAh battery, has extraordinary battery life... at least with Harmony OS 6.
xrisoneil
Picked up a Mate 80 Pro Max as a spare phone while in China last week, and it’s a beast of a device. After installing EasyAbroad, almost every app works fine, with Carousell being the only exception. The satellite feature worked flawlessly in China, though region settings block it here. Since I’ll be traveling to China frequently, having a mainland set with a local mobile planis a good choice, try out the grab and copy and it is awesome.
