Maximum Disruption period for Uni?
If i ord in Sept but i have Special term for uni in may. is there any chance of disruption?
I think the special term bridging program is really impt for poly guys too
reddevil0728
Why like that ah? The Special term is deemed unnecessary?:s11:
It's the same theory, you are leapfrogging other people.
Why should they let you disrupt if you are going to gain an advantage against your peers from the same cohort.
That's if TS is referring to this Special Term,
http://www.nus.edu.sg/registrar/event/specialterm.html
Where,
"...the Special Term is mounted to cater to students who wish to graduate earlier. NUS welcomes those who have completed their full-time National Service and who have places reserved for them in NUS to register for studies earlier, if they wish, during the Special Terms."
Kiwi8
Deluxe Member
Where,
Huh? Then those who enlisted early, ORDed early, are not gaining advantage against other peers from the same cohort who are not able to attend the special term? :s22:
marigoldhl
technically there isnt any advantage. those who ORDed early is probably the JC batch, who probably enlist earlier. typically JC kiddos have no exemption and have to study 4 years of uni. for poly, some may have half a year or even a direct year 2, so by the time they graduate those in poly would graduate at the same time, if not one sem later than the jc batch, assuming both batches are born in the same year.
anyway not many people would go for special term, henceforth mindef thinks there isnt a need to allow disruption for special term at all. if not it's pretty unfair to everyone else who doesnt take special term and rather matriculate in august instead.
Sent from Bonnieevee Haven using GAGT
reddevil0728
Ok need to establish some common understanding first so it will be easier to convey the message.
When I say COHORT, I am referring to either JC Cohort or Poly Cohort.
JC Cohort means people who complete their A Level at the same time say for example end 2011.
Poly Cohort means people who complete their diploma at the same time say for example first half of 2012.
Cohort doesn't necessary mean everybody who born in the same year. It's the POLY/JC that depends their "Cohort"
There would be 2 enlistment batches for each Cohort. So fro example...
JC:
1st batch
Enlistment: Dec 2011/Feb 2012 (PTP/Enhanced) respectively.
ORD: Dec 2013
2nd batch
Enlistment: Mar 2012/May 2012 (PTP/Enhanced) respectively.
ORD: Mar 2014
Poly:
1st batch
Enlistment: Jun 2012/Aug 2012 (PTP/Enhanced) respectively.
ORD: Jun 2014
2nd Batch
Enlistment: Sep 2012/Nov 2012 (PTP/Enhanced) respectively.
ORD: Sep 2014
So for JC cohort, regardless of which batch you enlist with, you can still attend special term in May without the need to disrupt (assuming you have a peaceful NS life)
Whereas for Poly cohort, regardless of which batch you enlist with you will not be able to attend special term in May as you have not yet ORDed.
So why should they grant disruption to poly cohort people to attend special term which will allow them to leapfrogged their peers from the same poly cohort given that they are not at any disadvantaged.
You can't say they are at the disadvantaged to the JC cohort given that it's not a like for like comparison anyway.
Anyway this principle applies to the other thread about the guy who AWOLed to go Cambridge to study Medicine.
Disruption is about not being at a disadvantaged as compared to your peers from the same cohort and not about letting you gain an advantaged as compared to your peers from the same cohort.
