Mazer products
Singrish
Anyone can share their experience?
Was searching for Belkin Boost Charge 3-in-1 Wireless Charger but the shops didn’t have. One shop recommended Mazer EnerG Wi.Desk Trio instead.
The Mazer is not exactly 3 in 1 since u still need to use the apple watch charging cable although i guess that’s not a big issue.
Just that Belkin is a well know brand wherelse Mazer is a lesser known local brand.
firesong
Deluxe Member
Sis bought a couple of Mazer cables before. I bought similar ones on Aliexpress at 1/5 of the price, so taobao prices would be even lower.
They are just rebranded Chinese OEMs, but of a noticeably higher quality than the cheap ones. I'd go with whatever you can get. Brands like Baseus and Ugreen are the entry level for high quality stuff for me, imo. I feel Mazer tends a little too highly priced for what I get, but that's just me.
Icterine
For tech accessories, go for Ugreen hands down. Highly regarded for its price and quality, you're getting the best of both worlds. If Ugreen doesn't offer the particular product you're looking for, I"ll go to AliExpress and read the reviews very carefully before purchasing. You may be surprised by the quality of some unbranded chinese goods. Chances are it performs exactly the same as a mazer product at a significantly cheaper price. However, if you wish to support local, by all means go for mazer.
Kopislayer
Do not get the Mazer wireless charger. I bought the dual charge from Harvey Norman for $69. It doesn't work at all. The product is very cheaply built. feels like it'll fall apart at any moment.
trans168
I bought a Mazer handphone holder for the car, the one with a suction that was supposed to stick to the back of your phone. Didn't work after a few days. Exchanged and still the same.
