MBP Overheating
IronMac
I suppose even if you turn off or turn on, you wouldn't feel much difference. All that you feel is what you want to see :)
blah blah
Tell me 1 million IT personnel uses it and certify it's working, it will be a more convincing feedback versus 1 million people with only 5% of them are IT personnel and yet not necessarily equip with the right knowledge to assess FreeMemory's claim.
I hope it make sense to you :)
Well, yes, it does. I'm going to wait to see if a beachball appears. :)
davidktw
isnt beachball means please wait?
Yes, waiting for ? :) Throughout my experience with Mac OS X, beach balls happens quite often in the first few iterations of the OS, but really seldom or even occur to me anymore since Snow Leopard. I can't remember when is the last time I observed the beach ball of death(really, it's like it has never exists since years ago). One thing is I moved on to SSD, another is I have a pretty powerful MBP.
However there are various reasons why the beach ball of death does occur. It could be hard disk related, network related(especially DNS resolution), a rouge runaway application causing processor hogging or deadlock in some cases. Memory cases while possible is seldom.
But I don't really see it as a good indication of memory issue, though it does indicate there is a bottleneck or issue somewhere. Before you start blaming every spin ball you see as memory related, you must understand that changing the way how memory is handle is a global effect on the system. It could be one of the subsystem not utilising the memory properly causing memory leakage which in turn cause large amount paging in the end. Then it's not the memory subsystem at fault. Your FreeMemory pick up the issue and purge away the leakage, but the main issue is with the software you are using, not with the memory subsystem.
If your system is a long running server where user intervention is not possible, then basically FreeMemory didn't do much except that you explicitly initiate a memory sweep. It is not at all an indication that it's doing a better job than the kernel, it is you an extra handle to manually sweep the memory. In the end, instead of have an automated system, you end up as part of the system doing manual jobs. :)
Rock-kun
All i did was typing a report on pages and surfing hardwarezone. Using it in an aircon room on the desk and it's gotten so hot =/.
Macbook Pro 2012 mid 15" with 256GB SSD and 16GB ram. What to do, cooler fan doesn't cut it for me because i can't bring the fan to school.
You do understand, do you not, that one of the possible reasons for a Macbook heating up so quickly is due to the fact that Apple uses smaller fans than the average Windows / barebones laptop chassis AND puts the vents at a position (typically around the hinge area) which would be hidden from sight by the user but actually does squat for cooling the system, wheras the average Windows notebook is littered with vents all over the bottom and the sides?
You can always take a good look at the teardowns conducted by iFixIt if you want to see how the insides of your MBP are actually arranged.
maxell_555
Make sure no clothing below laptop. I used the thin (5mm) circle adhesive foam below my MBA. Used the black foam from those $1 shop. Pasted in near the rubber stands on Macbooks, the flat surface. Improved my MBA cooling and preventing any water entry if table have water spots. MBA owners should know that new MBA design is so flat. It is (mm) near the table surface. Water entry and damage is very likely. Take care!
So, I hope the $1 investment can go a long way if it makes your Macbook last longer (cooling). And prevents any likely (water or dirt) damage to your logic board, SSD or fan.
P.S. Do use dust covers for any unused ports on any Macbook.
Cheers!
KELVIN
