MBP water damaged
meepok2006
Today damn suay. My water bottle somehow was not tightly closed and water leak in my bag, with my MBP. Now cannot on cause no batt and I can't charge. Anybody know the price and how long it takes for repair? :( thanks
IronMac
Don't try to turn it on anymore!
Put it in rice or silica packets before taking it in to a shop asap. I've heard that those may save smaller electronics but never something as big as a MBP.
meepok2006
Hi all! My mbp has miracle-ly revive! I can't even believe that. i went to epi centre wanted to get this fix. This front line personnel was very patience in trying to charge and switch it on. If you have read my first post, it can't even on or charge it. A few minutes later, green light pop up from the charger! She switch it on and told me to consider sending it for diagnosis as it will cost me a lot to repair. She was kind to do a simple diagnosis and only the battery and screen were faulty. I decided not to send it for diagnosis. At home, i plug in my charger and the battery began to charge! now i just need to replace my faulty screen as it will blank out suddenly. Anyway to bro ray***, sorry that i took so long for reply as i did not see your pm. i just replied you so hopefully you can drop me a msg :)
