sorry to hijack, any recommendations for full keyboard with tk that costs below $100? looking for brown switch haha, the one that is refurbished left with pink led only![]()
you can get Ducky Zero full size non LED for $99 at Xtremesolution at sim lim sq, i think thats brown switch...
rosewill keyboard sub par bro... easy spoilt..Ducky Zero better
user problem lah. the weak port part on the keyboard, as long as you don't plug in and plug out and keep the keyboard at the same spot you will not have this issue
When looking for mechanical keyboards there are a few things i looked into.
1. Non leds
2. Costar stabilizers
3. Detach usb cords
4. Brown key switch
5. Full size
6. No additional macro keys
7. Bluetooth
And so far only 1 keyboard has it. Filco Majestouch 2 Convertible.
Just preference or got any reasons for the non led?
Both. Led have the tendency to fail.
And when it starts to fail, its like a virus. It spreads.
And its a pretty hit or miss. Some could last quite long. And after that it shows some signs of led blown.
Nice to see, but when it comes to reliability, non led is still the best and comes with one lesser problem.
on the same dayWhat's the damage? I want try Topre also but $$$I just bought a Topre TKL 55g KB replacing my 3 year old Majestic Touch. Omg, cannot go back to mechanical switches liao. End game keyboard for me![]()
Must feel first then know ma... Review say its quite different from actual topre. Hmmmnvr use novatouch before. Get from taobao instead of massdrop. 50% savings sia... massdrop prices with shipping, might as well buy retail..![]()
Sent from JARVIS using GAGT
how much from tb though?I have a realforce 87u topre 45g... errr to me not much different compared to rc930 45g after removing the o rings.. its slightly lighter then topre 45g. Mayb novatouch more closer to topre..
My k95 (non Rgb) has the white leds going out one after another until only about half left. The rgb version seems to have that static discharge led jibaboom problem fixed though. The keyboard is solid apart from the leds. Dedicated media keys plus the awesome volume control knob are the plus points.
Sent from Sony D6503 using GAGT
