Bro. You can help set up a workshop ar. Help the meizu users zeng / root their phones.I can start a class...so many ppl hv issue with flyme
There is a icon "update" press that. U will see which versionanyway how do i check if i got the unicom/mainland/international version?
When you switch on/off, you will see the China Unicom logomine says i'm using the latest 4.2.0.5U
so u means unicom? but the box label says TD-LTE
so I'm really confused about this.. I thought unicom is paired with FDD-LTE?
the intl version just has preinstall google...and rom in englishBro. You can help set up a workshop ar. Help the meizu users zeng / root their phones.
Currently I am on the PRC OS edition. Want to change to the International one instead but not sure the exacts steps. Saw online the procedures but scare later wrong move. Brick the phone.... So gotta wait for the SG Meizu dealer to open shop / service center then go down ask for help.
Sent from Meizu MX4 PRO using GAGT
Was "U" ...change to "A"When you switch on/off, you will see the China Unicom logo
Also you should be getting some software update. Press 'upgrade' icon
Go to security app > permission > go enable the apps in start up. Then to be safe, in the same app, go to power saving and enable the apps to run in backgroundHi Guys,
I will like to start these two apps upon start up / reboot so they can monitor my data usage either via Wifi / LTE but i'm unable to do so.
My Data Manager - Data Usage
https://play.google.com/store/search?q=my data manager data usage&hl=en
Onavo Count | Data Usage
https://play.google.com/store/apps/details?id=com.onavo.android.onavoid&hl=en
this is what i did
1) Setting, App, Onavo Count -
2) Permission Management - Auto Launch / Notification (Click / Colour)
after rebooting, i go into the apps, RUN, i dont see these two apps running ...
even though other apps are working fine (swift key, muzei live wall) ...
is there something / a step that i missed out ?
lastly, if i press the app to launch it and close it via the bottom swipe to close recent app, does these two apps continue to run on the background ?
how can i make them as permanent apps running on the background ?
thanks
Can you use the lte in Singapore with this set?Does anyone know if I have the correct version?
Stock ID is M463U. But the label says TD-LTE.
But according to their release specs M463U has FDD LTE. Or do they mean there are different variants available for M463U?
Hmm can I ask what are you worried about if you're on 3G only plan? Anyway if you want to be sure, borrow friends sim card and put inside the phone to test if can use 4G, that's the simplest wayi have no idea. I'm not on a 4g plan. But I can get both the G symbol and 3g symbol.
