Mi Max 4
104305
I also have this mind, wonder when the mi max4 out?
Sent from 小米,大屏 using GAGT
104305
Xiaomi Mi Max 4 Introduction - 7.00 Inch Display, 40MP Camera, 8GB RAM, Features, Specs, CONCEPTS!
Valien
When? I'm about to buy Mi Max 3 as Christmas gift for someone.
104305
mi max3 is not bad a phone if you like big screen.
FinalTidus
I think i will wait till mi max 5 is out..
Heard 4 is only a slight upgrade over 3.
windwaver
That is a good move. Don't think Mi Max 4 will come cheap initially.
Aiya, I spent so much on Samsung phones previously so now got to 'make back' a little. Buying a Xiaomi phone 1 gen back is best value.
888888888888
19.5:9 aspect ratio
R N7 is very smooth, however I do not want this format it is very difficult to read ebooks. tall skinny thin chopped off at edges. flick through news very quickly not great to read. good for games, videos probably.
i think i'll need go to 18:9 minimally. the videos i have currently stretched to fill.
https://www.youtube.com/watch?v=Dx2Qeo6rdRY
A long giant cinema screen.
foxer77
max 3 already start at $300 ++ for imported phone. dont think it will come cheap.
davidwong
I suspect mimax4 might make Easter egg appearance during China note 7 pro launch since mimax 4 is note 7 pro + nfc
i1magic
My guess is that MM4 will be using SD660.
Probably till MM6, then we may see SD710.
bullsback
SnapDragon 675 is ok. But may not be strong enough to "salvage" Mi Max series.
They should allow 855 for mi max 4 pro with internal liquid cooling heat pipe
Sent from Xiaomi MI MAX 3 using GAGT
matrix05
When is Max4 expected launch date?
If is 7" + SD675/845 + battery 6Ah = pubg killer. 8x scope + 7" can KO tablet players.
