Micro USB to Lightning adapter
sp0inK
Can I use a standard android/blackberry charger for iphone 5 if I buy the apple lightning adapter and connect it to the charger?
jq75
Yes
U may get incompatibility message, but it can still charge
Not sure if it can sync
PetPet
Moderator
Moderator
If you've the Original Apple lightning adapter, you'll not receive the incompatibility message.
LonelyMan
I used android charger, quality 3rd party charger from Innergie and portable chargers with quality micro USB cables, along with the adapter, no issue.
Cheap chargers and usb cables I do not use, so I do not know.
ragnarok95
Senior Moderator
Senior Moderator
Yes
If use with original lightning adapter there will be no incompatibility message. The usb cable you can use any.
