micro USB to lightning cable
denn23
is there such a thing?
I've been googling but I can't find any. It usually a USB micro plus convertor plus adaptor.. =/
i just need one cable. one end micro USB.. the other end Lightning head.
appreciate any feedback
thx
LonelyMan
Micro USB is suppose to plug into Android phones, power bank to charge power banks or other device. What is ur intention to get a micro USB to lightning cable in the first place.
what88
thx
I bought one of this from Qoo10, so far so good.
It was a micro usb cable came with a lightning adaptor. No problem when connected the cable to IPhone, can charge and sync. :)
denn23
the power bank i have only has ONE micro usb port. So I wanna get the cable to charge my iphone directly.
denn23
that was my next best solution.. could you share the link/vendor pls.
Qoo10 is fairy messy for me. I went to search through a couple of shops to no avail.
thanks
LonelyMan
Seriously i still do not understand what you need. Ur power bank has a usb output port or a fixed cable micro usb?
chehjin
I believe he is looking for a Micro USB head (connect to power bank) to lighting connector (connect to iPhone)
I don't recall seeing such product., anyway, this power bank got give u micro usb to micro usb cable? if have then just get the adapter as shared by the others
what88
I though normally power bank have 1 or 2 USB port to charge other device, while the micro USB port on it is use to charge the power bank itself.
USB port = output
Micro USB = input.
chehjin
dunno leh, he say his power bank only 1 port. i also never see before
denn23
USB port = output
Micro USB = input.
mine only ONE port. both for input and output.
denn23
U are right.
but they didnt give a micro USB to micro USB cable. Yes.. very strange. i know.
the reason why theres only ONE micro USB port is because its a really slim powerbank. good when im on the road for meetings. the problem is that with so many adaptor and what nots.. the wire becomes BIGGER than the bank itself.. very silly.
so im trying my luck find a micro-usb to lightning head. its just more efficient to bring one wire out instead of so many wires and adaptor to use one silly power bank.
my pockets are only that big.
runningman.snsd
can take a photo of your portable battery?
interested to see 1 with just 1 usb port for both in and out charge
thanks
chehjin
i suddenly remember you can get a USB - USB adapter.
it is used to join 2 usb heads together. I bought from sim lim before.
basically it is like this.
power bank <->(micro) to usb head<-> (usb adapter)<-> usb head to lighting head
so basically you are using 2 cables joint together to achieve what u need.
that adapter few bucks only. I still have it.
denn23
or a micro usb wire and a micro usb/lightning cable.
one wire, one adaptor.
still cant find a dedicated micro usb to lignthing wire though
LonelyMan
I know liao. This is the stupid powerbank sold in challenger. Ask for refund or dump it if refund is not possible. Such a waste of time. The restricted number of certified cables will cost u more headache in future.
