Mid range gfx for COD Advanced Warfare
sp0inK
I guess the best is to get a 2nd hand card to play this game ? price range around $150
imo, don't ever buy second hand graphics card. especially those that have been used for quite awhile. the cheaper price not worth it considering it's not uncommon for gpus to fail after a few years. best is to buy a graphics card still under local warranty and hope it fails just before warranty expire if you wanna buy second hand card.
Felfirez
Er... What are you guys talking about? He's asking for a low/mid end card to just play CODAW, not run it at maximum glory.
TS I'd say go with MoneyFace's recommendation. Or a R260x/gtx760 are good too. Just off MSAA and turn down textures and you'll be having a smooth game play.
shadow84
760 nt worth its price.... palit 660 shld b a better choice.
bencheongcm
Thanks for all the recommendation. Will let my nephew know on the details. SO best bet is a GTX660 ?
Goodshot
gtx 760 already is min requirment , 660 suppose can play only at 720p mid setting at 40fps. Can play is 1 thing , lag or not lag is another thing
Alternative X
I disagree. GPU benchmarks of COD:AW suggests that a GTX 660 can play this game at max settings in 1080p with the AA turned off.
720p is very easy to run, think AMD A10 APU can also play COD:AW at 720p as well.
Goodshot
Is up to personal preference ba , i myself feel this type of graphic demand game no 280x no talk lol . i just hate games run below 40 fps
Alternative X
Check out the GPU benchmarks from gamegpu.ru. (This one is 1920X1080 with the AA turned off.)
http--www.gamegpu.ru-images-stories-Test_GPU-Action-Call_of_Duty_Advanced_Warfare-test-new-cod_1920.jpg
A GTX 660 can also play COD:AW pretty well unless you like to play with AA turned on, then I have nothing to say.
Goodshot
Hmm , maybe it can run good actually . I havnt actually try 660-660ti before , i jump from 560ti to hd7970ghz , btw 560ti suck big time
Felfirez
For the time, it was the best bang for buck, trading blows with the hd6950 and hd6870. Define suck? Or is it just because your budget didn't allow you to go for better cards? :s8:
Goodshot
I already had better card , but when that time i was tight budget i still rather get a cheap used 280x. Dun wanna go anythng below that ;)
