Mini case: Build mITX first, add GPU later!
wwenze
Really modular siol
https://item.taobao.com/item.htm?id...315dd38ec1c838cfcef817b2a37c1&spm=a230r.1.0.0
wwenze
how does one get power to the gpu once you add one in??
When the main PSU turns on, voltage goes to 4-pin molex, then the relay will turn on, and short the power_on signal of the second PSU 24-pin connector to turn it on.
watzup_ken
If I use an Ampere cooler as example, the hot air will be blasting downwards towards the vents for the main system. Then you will need another PSU to power the GPU, which means the PSU and cables are going to stick out in an otherwise, quite neat modular case.
