Mini-ITX help!!! urgent!!
guess890
hi all, gonna need to build 1 by today.
usage pattern
  • Basic usage, no games. viewing of some forex quotes is the most intensive usage
Need
  • 20 inch monitor w/ vesa mount, (no bigger than this)
  • system will be mounted on monitor
do not need
  • ODD, OS, keyboard, mouse, speaker, GPU, wireless adapter
CPU & Mobo: Pentium G1610 & ECS H61H2 I2 $104 / MSI h61 I35 $139
Ram: 4gb
ODD: none needed
HDD: toshiba 2.5 inch @ $56
Case: inwin BQ660 @ mynextcom $100 (Intel HSF can fit?)
Monitor: (please advise on this, must be able to mount the system)
  1. Philips 200V4LSB, cybermind $159
  2. AOC E2050Sda, fuwell $145
  3. Viewsonic VA2037m, fuwell $149
any alternatives? i would like to reduce cost further if possible. budget should be below $480
Prices taken from tradepac
t258jgn
ECS H61H2 I2 & MSI h61 I35 still available? EOL very very long ago.
OlympicDreamer
It is still available, I just bought from tradepac when I saw this thread.
For monitor recommendation, you should go monitor forum and ask instead..
coyote
AsRock B75 ITX + I3 3220, Cooler Master Elite 120 Advanced ITX chassis + FSP Hexa 500W psu + 4G Kingston value ram + 500G WD Blue harddisk. Prolink Wireless Laser mouse + keyboard. No monitor. Output straight to your 42" & above Full HD TV(anything smaller than 42", texts are too small to read from Sofa).
MoneyFace =p
Hunt for Antec ISK110 VESA around SLS unless you don't mind the jet engine running inside BQ660.
rAcEr
What jet engine in bq660? I'm running a g2010 n quite quiet lei! Fan speed averages 2000rpm n cpu/mobo temp hovering around 45 degree medium load
