Mini ITX Substitution Advice
huffie
Currently have a MSI E350IA-E45 which has failed, would like to know if anyone can advice if there are any other mobo that has identical size so I can rebuild another PC using the same casing? Seemed like nowadays, it's hard to find. Or I've totally lost touch. TIA!
gbpdem
i might have a used one lying around somewhere in my cupboard
let me check tonight and if i find it
you can have it for free if you can drop by marine parade area
huffie
Thanks. do let me know. :)
huffie
Looks like a standard ITX board to me, plenty of choices in the market.
actually I prefer to stick to MSI as I find Asus's products abit overpriced. so far I've seen 3 ITX from asus, 1 from Gigabyte and 1 (gaming board) from MSI. that's why I find it abit restrictive :(
MoneyFace =p
ECS NM70-I2 @ $100
With Intel Celeron 1037U
gbpdem
Bro I realized that my MSI E350IA-E45 could be
at my dad's place and he is currently overseas
and would not be back soon
So I can give you another board if you don't mind
I have a spare used Asus E35M1-I DELUXE
which is a much better board imo with passive cooling
gbpdem
This is the one :
ASUS E35M1-I DELUXE Fusion AMD E-350 APU
(1.6GHz, Dual-Core) AMD Hudson M1 Mini ITX Motherboard/CPU Combo
mikafire
can go for upgrade?
similar MSI E350IA-E45 as u n im considering tis: http://forums.hardwarezone.com.sg/hardware-clinic-2/%5Bnews%5D-zotac-zbox-ci320-nano-mini-pc-coming-later-month-just-%24360-4768930-4.html
