86technie
- Jun 8, 2006
I be brief about what I think of Logitech Z625/Z623 since both speakers
are identical. Except that the newer version Z625 comes with Optical/SPDIF
input which is useful for console/TV.
Please take note that my testing involves a soundcard so not onboard soundcard. If you are using with onboard sound, the sound quality
maybe different than with a soundcard.
My setup as follows:
Dell G3 i7 geforce 1050 SSD+1TB HDD
Sound Blaster X-fi Premium Music (RCA and optical output)
Logitech Z625
Build/Size
The left and right side speaker are plastic material and they are of decent size so can place beside monitor and etc. nicely.
The sub wise is really massive, it is wood material and you can except really big and deep bass coming out from it.
Initial testing issues
As I am using a soundcard, I face a issue that if I set to 100% for my PC volume. The sound is really loud that I had to tune it down to 50%
and on the speaker itself is 50%.
The bass is really loud and thumping when the knob is turned all the way to 100%.
That I had to turned it down to about 60% as the bass is really loud.
Music
TBH Logitech Z623/Z625 is tuned more for movies/games than music.
Music wise is OK especially the deep thumping bass.
Mids are OK but if compare with Klispch Promedia.
Promedia mids are much better than Logitech Z625.
Bass wise Logitech Z625 wins over Promedia.
Movies
This is where Z625 shines, effects like rumbling, tremble and etc.
The subwoofer really exceed in creating the effects.
The speaker also able to create a expansive sound stage
thus surround effect can be heard.
Games
Playing games like first person shooter, thanks to it's impressive bass.
Gun shot, explosion thanks to it's sub.
It's effects are loud and deep.
The speaker also able to create expansive surround environment.
You can hear enemies from either left or right channel.
Overall
PC 2.1 speaker choices are really limited.
There is Klipsch promedia but I gave up on it.
And Logitech Z625 which for so long I never wait to give it try
until now.
Since most know it as a heavy bass type of speaker which is true.
The mids are not that as great as compare with Klipsh promedia
or 2.0 speakers.
A tip is don't adjust the bass all the way if not the bass will just overpower
the mids and etc.
Logitech Z625 for movies and games are great.
However if you are serious music listening, you can get a set of this speaker
than get another bookshelf 2.0 for that purpose.
These days to me it is hard to find a speaker that are all rounder.
Between RCA and Optical, Optical sound much clearer than RCA so
if your PC support optical do use it.
Any question feel free to ask or discuss.
Logitech Z625
Build/Size
Music
Movies
Games
Overall
until now.
or 2.0 speakers.
the mids and etc.
