This is poisonous
Anyway my air cooling cost around the same also hahaha. Maybe even more expensive... hmm
Thanks dudeWow. nice temps. great setup mate. enjoy ur overclocks and golden acoustics.
Wah I thought a lot of pictures liao... heh... the rad extends outwards enough with the help of the rad box, does not block the graphics card output, otherwise I can't use my computer rightcan post more pictures. thanks.
will the rad block the graphic card ouput port?
Of course with this arrangement the amount of space at the back a bit limited - a bit cramped - but no problem, I'm using a number of ports where the rad is located. Can always put the rad inside the case (if got space) or on top (if there's a way to mount)...
Will put more pics up when I 'update' my setup in the coming days/weeks...![]()
Yes, have a look here: http://www.coolingconfigurator.comHey there,
Just wanted to ask, is there an AMD-compatible block or something like that?
Cheap and goodyate loon ftw !
You could contact sabe @ http://www.edge2o.com to bring it in for you if he does not have the stock![]()
There is only one radiator i know where there is an issue with top placement (very hard to find that rad anyway), the others all no differenceradiator if move to top panel will affect performance instead?
As per the pictures on the first page, I mounted it at the back of the caseo.o nice cooling system chiu have there...
and since chiu oso Lancool K62 user, where chiu put the radiator? I heard K62 not much places put radiator...
Depends on how much premium you put on silence + cooling efficiency + aesthetics... its up to you really... of course its quite strange to wc a budget rigThanks for the reference
Is it worth the money if I WC an AMD?
Edit: specially for you... I realised that on the rad photos on the first page, the angle is a little misleading, there is actually a lot more space than it appears there... see:
I think there were some issues with the MCR Drive and as such it is not widely available to resellers, and from what I hear it is actually more expensive than buying individual components. You can try asking sabe about it.i was thinking whether to use to MCR Drive (pump, rad and reservoir together). quite worried about the rad blocking the ports behind. thanks for that special picture.![]()
i last question, is your pump secured with screws?
Depends on how much premium you put on silence + cooling efficiency + aesthetics... its up to you really... of course its quite strange to wc a budget rig![]()
