Mobile Processor Raw Power
CrispyPeddler
Kinda out of touch from the mobile arena. Just wanna ask in term of "RAW POWER"...which chip now leading? A11? 845? Kirin 970?
ZrE0_Cha0s
oh haha my bad XD cos i rmb the whole length of the chip set rather than just number :p
like Apple A11, Samsung Exynos 9810, SD 845. Kirin 970
watzup_ken
A11 > 9810 > 845 > 970
Sent from HUAWEI MATE 10 using GAGT
Exynos 9810 may not be as fast as the SD 845 and even Kirin 970. In some benchmarks, it seems fast, but in real world usage, the processor throttles a lot and not properly optimized.
watzup_ken
Krin 970 basically driven by Cortex A53 core.
Its an octa core SOC, not that different from the previous gen SD 835. Not sure what you mean when specs show that it's driven by a combination of A73 and A53. Benchmark result wise, it only loses in GPU against the SD 835. Unless you mean to say SD 835 is also basically driven by A53.
Audiology93
4x A73 and 4x A53. A73 do all the intensive work but the A53 handle the light task.
I only took into account the CPU power. If comparing GPU, the 845>9810. But if comparing just CPU, 9810 is faster.
CrispyPeddler
so in your opinion SD845 still the best? aside from A11...im looking for phone with high battery endurance, fast charge, speed and durability....mate10pro p20pro one+5T/6 samsung s9+
Audiology93
High battery endurance, you're only left with 845. S9 and S9 Plus with 9810 have many issues especially battery life draining if you've visited the S9 thread.
Hailgod
sd 845 > ex 9810 > sd835 = kr970 > sd821 > sd820 > kr960 > sd660 > sd636 > sd625 = kr659
honestly anything above the sd 660 is very good and have very little difference in app opening times.
Sent from Xiaomi REDMI NOTE 5 using GAGT
