mobo died. need help.
bikoyski
my rampage II gene has bid adieu.
I'd like to use most of what's left from the system so I will appreciate any help on what to upgrade to.
Here's the old setup:
Asus Rampage II Gene
6Gb RAM (can't) remember the bus speed
R9 280
Modular PS
120Gb SSD
1Tb HDD
I'm guessing I just need a new Mobo, CPU and RAM? My son can pretty much play all his games so a new CPU/mobo/RAM combo that performs close to the old one is OK. Budget of $500.
yusoffb01
Just get any i5 and mobo that use ddr3 then can reuse rams
lcheowl
R9 280
Modular PS
120Gb SSD
1Tb HDD
What games your son is playing?
going skylate with a H series mobo and getting the ram from amazon will need more than $600.
bikoyski
Hi, that'd be great if I can reuse the RAM. I'm not really well versed in CPU and Mobo as you can probably tell with my previous posts I only get my info from this forum. Would you mind recommending a combo?
bikoyski
found this in one of the threads,
CPU+MB: Intel Core i5-6500 + GIGABYTE GA-B150M-D3H @ $449 (PC Themes)
RAM: Kingston ValueRAM DDR4-2133 CL15 8GB @ $57+3"
seems to fit my budget.
