Any option to be clamp onto the table?
Ya have also! You go caurosell search for monitor arms under computer parts, they should pop up for you liao!
As for fitting i think pretty universal one the four holes should fit just nice!
Bro, which NB series are you using? So far i went through F80-F150. Non actually support ultrawide...
If you don't mind buying from amazon with the shipping cost in mind, you can consider Ergotech. Recently bought it for my Alienware AW3418DW and is very sturdy.
How’s the arm holding up so far? Any issues?
Since we are here, would you guys get Acer X34P or Asus PG384Q?
