Monitor Arm for Ultrawide Monitors
Hasagi
Hello! Does anyone have recommendations on monitor arms for ultrawide monitors? The North Bayou F80 seems like a good deal at $40, however it states that It only supports 17 to 30 inch monitors, with a weight threshold of 2.0 to 9.0kg. I have a 34" monitor which is 7kg. I enquired if the NB arm could support my monitor, but they mentioned that it was not possible.Does anyone have experience with this NB monitor arm for ultrawide monitors that are above 30"?
I would also appreciate it if anyone can recommend other monitor arms that are around $50. Understand that there are other options such as ErgoTech, ErgoEdge and the Prism monitor arm, but if possible I would prefer not to pay those prices for the arm (~$100).
Thank you for reading!
DavidChieng
Check on Carousell for refurbed brand-name arms. I picked up a HumanScale arm rated for an iMac for $80; using it with a Dell 3419W.
comcrepe
It should work in theory. You can always check out the reviews on amazon. Either that, take the plunge and order online to ensure you can return the item if it does not work.
hg2
Recommend Locktek heavy duty arms from amazon for large and heavy monitors.
bleachberu
I plan to get a tv style mounting bracket for the wall instead of an arm, due to my built-in desk limitations.
SEvsNK
Im using the North Bayou F120, you can get it on lazada for $35.
Using it for my acer X34 predator for the past 6 months, just for additional info, the monitor weights at 7.4kg without the stand. Hope that helps
genocideX
is that nb f120 a wall mount?
Shutterbox
Due to workdesk dimensions and contraints, I can only get those arms that sit on the desktop, like V-shape kind of legs
thought of getting an arm that can:
1) center vesa mount to support up to 34" curve screen (like xiaomi's)
2) left/right vesa mount to find a way to mount desktop monitors.
Apparatus
RE
Watch youtubes. They got recommendations for this type of thing
:D
Sneaky_ho
I am using NB F100A ($72 from AliExpress) with Xiaomi 34" but could have handled by F80A model as the monitor only weigh 6.4kg.
Hi bro, just gotten my xiaomi 34" yesterday and currently sourcing for a wall mount due to my ikea linnmon 150cm table. Not sturdy enough for clamp monitor arm. Found 1 m520 tvmountsg. $59 now. Can move in all motion. Installation $30 (included delivery) So total is $59 + $30 = $89 (next day delivery + installation)
Self collect is at gambas.
However stocks only coming in 13 oct 2020. So I currently surveying as well. My info is accurate as of 11 oct 2020 6am as I chat with the staff. Anything can wa me! Pm me for my number if you need.
