Monitor black off while CPU power running
eudorajjj
Hi everybody,
I would like to find out from you guys why am I experiencing this issue on my computer? Is it my video card, RAM or motherboard giving me this problem?
Thanks guys. Appreciate your time and guidance.
zacky1223
i had the same issue my monitor keep switching between digital and hdmi , maybe you can try connect your mobo graphic card to your monitor and see if it works :)
eudorajjj
Hi Zacky! Thank you for sharing your comment here!
I not sure whether my computer keeps switching between the digital and HDMI mode, but I experienced this while I was playing NBA 2K15. There are also times when I'm not running any games but surfing net, the issue surfaces. Nevertheless, I will heed your advise and try to see if it works.
Thanks once more!
shiroyuki03
do check if you had power savings on, for eg, like turning off monitor after 20 mins. thats the default settings if you did not modify the settings.
try another cable if you have spare. also update your graphic card temps here.
eudorajjj
Hi Shiroyuki03! Appreciate your reply!
Roger. I will have a look at the settings now!
Thanks!
eudorajjj
On a side note, I am thinking if I should get a new graphics card. The current one I have is AMD Radeon HD 5800 Series. The type of games I usually play are FIFA and NBA2K. If yes, is there any recommendation you guys can offer? Thanks!
jtjt00
Based on TS comment, likely is graphics card going up lorry.
TS, post all parts of your rig here like mine on the right -->
XNoblet
If all your settings are correct eg.power saving is off and GPU temps are normal, try oopening your casing and check that the psu power connectors to your GPU are plugged in properly/fully. Happened to me once and I just replugged the connectors to fix it.
shiroyuki03
that have to depend on your current system config. if you get a new one and your system is old, there will be bottleneck, and you won enjoy the full potential of the new graphic card.
that aside, im on the red side, *hint*, AMD. I would recommend Sapphire R9 280X. thats a pretty decent card. i have used for all my friends' new PC. and they are lovin' it!
eudorajjj
Hi Guys, below are my computer specifications:
Processor
Intel(R) Core i5-3470 @ 3.20 Ghz
Mainboard
Asus P8Z77-V LX
Graphics Card
Memory
Kingston 8GB DDR3
Display
LG Flatron E2260
Storage
WDC WD 5000AAKX-00ERMA0
Casing
Cooler Master
PSU
Andyson G530
I hope I have provided a rather comprehensive details.
Thanks for your help once more!
mib500
Processor
Mainboard
Asus P8Z77-V LX
Graphics Card
Memory
Kingston 8GB DDR3
Display
LG Flatron E2260
Storage
Casing
Cooler Master
PSU
Andyson G530
the gpu i think gonna dead already... cause 5800 known for alot of issue...
eudorajjj
Hey guys, thank you so much for your input!
I think it is time to upgrade my graphics card. Aside from Shiroyuki03's suggestion for Sapphire R9 280X, is there any recommendation you all have for me? The type of games I usually play are Fifa and NBA 2K. These games usually don't require very high end graphics card right (as I was told). Ideally, my budget will be around $200. Is it too little? I can pay more if you guys think I should go for a better graphics card that might cost a little more.
I appreciate your comments! Thanks!
mib500
its just nice... R9 280X should be sufficient for you need...:)
jtjt00
Sapphire got only 2 years warranty if I am not wrong.
eudorajjj
Thank you mib500 and shiroyuki03 for your suggestion!
For the rest, thank you for your guidance and help for pointing out the problem. Your advise and comments really have helped me a lot.
Many thanks to everyone who contributed to this thread!
