[Monitor] Crossover IPS LCD 27 inches
whyalwaysme?
yes i am using it now. It is supported.
However, the dual link dvi adapter is extremely unreliable. Sometimes must unplug and plug back a few times to get proper signal. Lots of people having the same problem too.
the adapter has 3 different firmwares. The latest is 1.03. Hopefully you get the latest one when you buy.
hi there. can i ask wat adapter ur using to connect ya macbook to crossover?
aces8080
he doesn't seem willing to share:(
pls note that it seems he bought the normal 27Q.
for usd 10 more, u could get one with tempered glass from red-cap.
but then again i bought 2 sets, not too sure if hes willing to let go at usd 330 for 1 set.
u can try
masotime
Has anyone tried HDMI to Dual-link DVI for these monitors? Any specialised adapters needed? HDMI 1.3 or 1.4 minimum?
whyalwaysme?
u can try
was it the guarantee dead pixel advert one? i tried w the glass one but was offered at us$350 for a single unit.
windwaver
As long as they deliver the monitor .. it is good liao. Refresh rate ... I am not sure how they do it.
PCBank has perfect pixel?
Crossover ... being most expensive ... should logically have better quality panels. But yet .... it is also about luck.
OK guys, I've finally got time to set up the PC Bank monitor. This is my review of the monitor in gmarket
No dead pixel guarantee from seller is true. Package is well protected with 3 layers of bubble wrap. Although there is a small puncture of the box but monitor is in good shape. It didn't get a perfect 10 because build quality can be better and there seem to be some loose particles inside the monitor.
Seller is very responsive and I'll highly recommend anybody to buy from him.
I tested for dead and bright pixels using Dead Pixel Tester 3.00 and no defects came up. Monitor stand is strong enough to hold it in total upright position.
Bought it for SGD$375 after coupon discount. Good price for such a lovely monitor.
Link for this monitor is here
Haven't buy yet, still undecided whether to get from Gmarket or eBay. Want to get some feedback here but not many people actually feedback here much.
I've repeated myself several times on buying from gmarket.
visuallin
If anyone looking to get a awesome gfx to drive their 27" ips beauties do check out my sales thread:D
aces8080
for those using the crossover 27Q
1) how do you know its the tempered glass version or the normal version?
2) How do you adjust the height?
Cheers!
Swiftbladez
gmarket price a lot cheaper. too bad I didn't dare to take a risk back then. Oh well, nevertheless enjoying this awesome monitor!
@aces8080
The listing for the tempered model will state that there is a tempered glass I believe.
the stand for the 27Q is not height adjustable I believe.
aces8080
@aces8080
I am loving my 27Q from red-cap! zero dead/stuck pixels and no backlight bleeding! only issue is that.... i ordered 2 sets and oly 1 was delivered!!!
emailed him and will be expecting a reply on monday.. else i might just cancel the order and reorder from another guy!
i1magic
They probably thought that you duplicated your order. But how many times did you pay them? Twice?
i1magic
Yes, bought from Happy Mall. Yes this is the same guy selling the Crossover Pivot.
Think after buying 2 of this monitor .... have to get a Asus GTX670 TOP card to power them liao ... LOL!!
Siao liao lah ... got to spend more $$.
Swiftbladez
lol you have been saying that you want to get the monitor for weeks and now still haven't buy :o
Edwin_Swee
went for 3 27q from red-cap too...speedpost just simply screw up everything...but red-cap service is top notch..
anyone going for any vesa mount??
