Monitor Flickering Issue @ 144Hertz
tadpol387
Hi Bros,
My monitor flickers whenever i adjust my monitor refresh rate pass 60hertz.
Details are as follows;
Monitor - PRISM+ F270i PRO
Graphic Card - Powercolor Red Devil Radeon™ RX 5700XT 8GB GDDR6 Graphics Card
Cable - UGREEN DisplayPort 1.4 Cable 8K 4K HDR 165Hz 60Hz Display Port Adapter For Video PC Laptop TV DP 1.4 1.2 Display Port 1.2 Cable
Video of the flickering;
https://bit.ly/2Myq1Fm
Quite sian that I can't utilise the 144hertz capability because of this.
Your help would greatly be appreciated.
Kindly advise.
Thanks you.
destiny88
try turn on/off freesync,
try another DP port.
if both fails use HDMI try.
If all else fails either 1 item is spoil
Vulpix
Moderator
Moderator
This looks like monitor issue leh. Did you try another cable first?
fzhfzh
From my experience, it’s DisplayPort cable issue. Try changing a cable. Had the same issue with my Alienware 3418
Vulpix
Moderator
Moderator
Serious ah? He so sway his dp 1.4 cable got issue? :(
Anarky
I had the same issue before.. few options for you to try before spending money on new cable..
1. Power cycle the monitor, unplug everything from monitor, until all power discharged, then plug in again and see if it's working now.
2. After trying 1, repeat but use a different DP port.
3. Uninstall display driver with DDU and install latest drivers.
If all else fails, buy a proper VESA certified cable.. UGREEN is not certified according to this database https://www.displayport.org/product-category/cables-adaptors/
Also no need to try with HDMI cable, HDMI doesn't support 1440p 144Hz
EDIT: is this the cable you bought? https://www.ugreen.com/product/4k_displayport_male_to_male_cable_1m-en.html
According to the specs it only support 1440p 60Hz
Bardiel
In before TS self pawn. :s13:
incase is driver issue : https://community.amd.com/thread/242557
tadpol387
- Tried Step 1
- This Prism Monitor only have 1 Display Port
The cable i bought is;
https://www.lazada.sg/products/ugre...p-14-12-display-port-12-cable-i348676594.html
purpleberry
If it flickers every xx seconds, probably due to bad capacitors if the above suggestion fails.
Vulpix
Moderator
Moderator
Oh man.. 18 bucks for non-VESA certified cable.. this UGREEN jiak money very well..
I wonder if Prism will let you RMA monitor before you test with another cable..
Actually it depends lah. Maybe the OEM of his cable got VESA certified but if they don't reveal we won't know. A 100% VESA certified HRB3 DP 1.4 cable is around 23 so not too far off.
