Monitor Flickering
zephyr11
NEW SAMSUNG CF390 27" not working with CSGO
NEW PROBLEM;
i ended up getting the 27" Samsung CF390 curved at sitex today.
everything working fine, but when i play CSGO, after i exit, it goes to black screen, cannot do anything except reset.
i searched online everyone had problems getting "into" CSGO, not getting out.
gfx sapphire r9 390
Samsung cf390
I've already tried installing and reinstalling all drivers (monitor and gfx), game.
nothing seems to work so far.
anyone got any idea what's going on?
:s22::s22::s22::s22::s22:
Hi all,
need some help, monitor is flickering, tried to change a HDMI cable, but not helping. no distortion, just flicker. everything else is normal.
flickers for half a sec and comes back, comes and goes.
gfx - r9 390 sapphire, just bought 4 mths back.
monitor - samsung S24D300 bought bout 6 mths ago.
any suggestions or help?
thank you!
ZrE0_Cha0s
Do u have other ports to test or other monitor and GPU to test it?
Could be possible port failure.
zephyr11
this port is on the monitor right? i think there's a vga, need to find a cable though.
Koenig168
Hi all,
thank you!
:s11::s11::s11:
You can RMA your monitor.
zephyr11
thanks Koenig;
so likely is monitor problem?
also another weird problem arise;
i tried to play CS, and it worked fine for awhile, then there was an auto update from STEAM, then after it became very laggy, not ping, but like i move my mouse it took .5 to 1 sec later then it will move on screen. i don't know if it's the update but i tried searching online but no one seems to be having problems with the update.
xtractor
i think the problem is from gpu why dont u try to roll back ur gpu driver see whether it work
i1magic
Hi all,
thank you!
:s11::s11::s11:
Since only bought 6mths ago, just claim warranty lah.
Anyway, if it continues to get worst and become like this video :
It means power supply is gone-ing soon.
zephyr11
thanks for the vid, mine the power didn't go off at all, was on the whole time. only the display flickering.
I will go back and check on the gpu driver.
thanks!
i1magic
thanks!
If the power button stay on, then take a torchlight and shine at the bottom left and see whether can you see the "Start" button. If can see, means LED backlight driver got problem.
Anyway, got warranty right?
Encrypted11
Hi all,
thank you!
:s11::s11::s11:
Bro, sounds very much like the recent updated UVD driver bug released in conjunction with the open sourcing of AMD's AMF SDK.
https://www.reddit.com/r/Amd/commen...imson_edition_16101_release/d8frde5?context=3
Try if 16.7.2 WHQL helps?
http://support.amd.com/en-us/download/desktop/previous?os=Windows 10 - 64
zephyr11
i1magic:
yes, under warranty, I might get it sent back to see what's wrong, but it's working fine for now.
Encrypted:
i'll go home and try the driver you shared.
thanks!
spiky0180
TS, I don't have the monitor problem like yours. But I have the same cs:go problem. Everytime I launch cs:go I have to toggle some video settings before the game is smooth. Otherwise there is some lag. I tried launching other games and I don't get this problem. I'm using r9 280, on latest 16.10 drivers.
How you resolve your CSGO problem?
zephyr11
I also have that problem!!! I'm using the r9 390, I haven't actually resolved the problem, but I think someone recommended that you try to update to latest drivers.
I didn't even turn on my comp the last whole week, go home, shower sleep. :s11::s11::s11::s11:
Allanlee82
maybe try to connect to your home tv and see if it still fickle, if it stop, most likely is monitor issue
spiky0180
I'm already on latest 16.10 amd drivers. I just reinstalled my Cs:go. Will update again if it is smooth
Encrypted11
I recommend trying a rollback to 16.7.2 WHQL. Older drivers, not newer. Current 16.30-16.40 branch drivers up to 16.10.1 have a midas touch with system stability when it comes to running h264 content... There are people on the polaris thread mentioning this workaround works.
