Monitor for PS4 suggestion help.
DragoonRed88
Hi, I'm looking for a monitor to replace my broken TV that I use mainly for PS4 and have narrow it down to two choice.
Benq RL2455HM(TN) and Dell U2417H(IPS).
Looking for suggestion from the guru here to see which is better and is there other I should consider? Budget is roughly $350
Personally, I like to have game look beautiful and nice when I play
I'll probably be doing a dual screen setup with my P2314H as well since I plan to have both monitor on the same table:D
Side question, for speaker, better to output from PS4 using a DAC converter or output from the monitor?
Thank!
jedi5diah
i prefer IPS
Speakers depends on your budget...anything is possible
yusoffb01
Thank!
monitor headphones to speakers. u can use both cpu and ps4 at on same speakers at same time
tigerwoods
i like my new Dell S2316H IPS monitor, great for games n movie, can consider
