monitor for pubg?
holtby176
Looking for recommendation for a new monitor mainly to play pubg, csgo, and other fps games in future. currently using a 19' 60hz HP monitor, running on gtx1060 6gb, in desperate need of an upgrade. Would like to keep budget below $200. pls advise on where to purchase from (lazada, sls etc.)
holtby176
will there be a huge difference between 60hz and 144hz? i am told this is particularly significant especially for fps games. if so then i am willing to spend slighly more
lifeishard
Pubg no need 144hz la, super slow game...see who got patience to camp only right? But yes, it needs a larger screen for you to see other players.
pr0dygi
I am also playing this game. Heard from many ppl that 144hz does help.
Im looking at Acer KG271A. 27" 144hz. Its $3XX though. Maybe u can look at the 24" model.
jayz89
144hz does help.
U use liao u will know. But u must first be able to get that high fps in pubg.
holtby176
144hz does help.
how high does the fps ingame need to be to utilise the 144hz? im currently running at 150fps in lobby and 60-100fps in game
darkazelf
Considering most of the game you would be camping you wouldn't need 144hz monitor, if you can actually get 144fps in the first place.
If play other fps games then worth getting, I got a Korean 144hz monitor for 250 on qoo10. Not the best but is close to your budget.
Sent from ZUK Z2131 using GAGT
holtby176
i think there's a misconception that the game is mostly camping. being able to spot enemies easier at far distances is a huge advantage in the game which is why im looking for an upgrade
mind sharing a link for that korean monitor?
darkazelf
Search Viewsync on Qoo10 or the Acer GN246HL on Prime Now which comes with local warranty. Those are the only budget 144hz monitors I'm aware of.
The point about spotting enemies, not sure if getting 144 fps is even possible or worth, since to even get close to it with your GPU, you will need to play on low settings which might affect spotting of enemies from far distance. Its still a worthy upgrade but I'd say you will notice it more with other games like Overwatch, CS.
lifeishard
You meant 144hz monitor helps in spotting enemy in far distance?
from what i heard from some players it does, seems easier to spot movement from far distances
No it doesn't, whether u can spot movement from far distances depends on how aware you are.
I play PUBG way earlier than the rest, although it's better now, but still not optimized. Your fps would shoot up to 115+ and dip to around 50+ through out your game, and having a 144hz monitor create so much screen tearing that I got headache after playing a few rounds.
Im using GTX 1060 6GB and BENQ's 144Hz monitor, everytime before game, I switch it to 60Hz and vsync it.
I got my BENQ for BF4 and CSGO, where it can sustain 120+ or more FPS the whole game.
jayz89
I got no screen tearing on my 144hzmonitor when my fps drops to below 60 when im in ***** pochinki or military or yasnaya.
144hz is more smooth but like i said, pubg unable to get constant fps above 144 cos the game is not optimised. Everyone know about this issue.
But if u play alot of fps game then I highly recommend to get one. If you got the money of cos.
thesmallprint
G-sync or Freesync is almost mandatory for a game like PUBG with fluctuation FPS. 144hz + G-sync is enough, don't need to go higher.
