Monitor goes to power saving mode???
_death_god
Hi guys,
After i power on my computer, my screen will go to "Enter Power Saving Mode" on my Dell U2414H. Cant even view the BIOS screen.
Then it will stay black screen till i force off my computer. After I on again, it will be the same.
Bought my computer on Jan 2014.
this is the part i am using.
i5 4570 with ASROCK b85m pro4
g skill 8gb
msi r9 280x
wd blue 1tb hdd
seasonic 750w
plextor 128gb ssd
does anyone experience this problem before? what component is faulty?
ZrE0_Cha0s
Wow another black out issues, well u can try using onboard GPU to test and see?
xtractor
Hi guys,
g skill 8gb
msi r9 280x
wd blue 1tb hdd
seasonic 750w
plextor 128gb ssd
can u go to safemode?try to press f8 if im not mistaken and see whether it boot..
if still cannot plug out the gpu,clean the gpu,clear the dust and clean the strip using rubber eraser,plug it in and see whether it works
_death_god
Try...
On your monitor first then on your pc.
i leave my monitor on for 24hrs :/
GPU --> PSU --> Motherboard
i guess its GPU
Hi thanks for the tips. I actually experience this problem few weeks ago and i use your method and it works. till recently the problem keep on re-surface. :(
after i plug out my GPU and use the onboard GPU, it works! i guess its my MSI r9 280x problem...
_death_god
since i found out the problem lies with the GPU, can someone help me on the RMA stuff?
i bought this computer from frotran in jan2014 and this graphic card has a 3year warranty, so it will end in jan 2017.
if i am not wrong, the GPU box have a "3YEAR WARRANTY BY CORBELL", but i did not register any warranty online for this GPU. is it still possible for RMA?
if it is possible, do i just bring the GPU for RMA or bring my whole computer?
what is the procedure like? i bring down my GPU exchange 1 for 1 on the same day? or how does it works?
kindly need some advice. thank you! :):)
xtractor
just bring only ur gpu to corbell and make sure u got the receipt......if u dont have any receipt u need to check on the date stick on the gpu board for the warranty
_death_god
i do not have the receipt, but the invoice(which includes all the parts i bought) from frotran.
yes i have the date sticker sticked on the gpu board. hmmmm will it be sufficient?
localITguy
Suspended
bro, invoice= receipt:s8:
make sure you make 2 copy of the invoice for safe keeping and bring 1 copy for ur RMA
