Monitor / GPU issue?
Sheldon3
Built a computer + got a new monitor, the screen become like this at random timings. Picture is here
Is this a gpu or monitor issue?
Specs are on the right side of post! thanks
alan_walker
bro are u coming from 5700xt gpu? I experience the same but the issue is gone after restarting the system. Although I can guarantee you it has nothing to do with monitor.
Sheldon3
hi bro, your system also half the screen dimmer? i restart also still same problem
tigerwoods
Don't overclock the monitor, try set to lower hz
Try different cables
Posted from PCWX using Jedi mind trick.
Sheldon3
Stock 75hz on monitor, tried using other cables. I think its the gpu as previous reply posted a reddit page about this issue.
namex123
why don't you check monitor setting menu.
look i also have half screen my old Samsung 931BW monitor :)
Sheldon3
My monitor no issue. You have to go check you own
Monitor menu.
pretty sure its the gpu issue, as on the reddit page posted by the other guy few replies back. people who are using the same gpu are having this issue
namex123
If your gpu card got warranty then bring to service center
Let the tech guy check the faster way. Hehe.. :)
shawntyq
try set pci-e to 3.0 in bios, default is auto.
cos i believed some users said it is running 4.0 even tho boards arent supporting it.
not sure if it will help.
