monitor - hardware question
Hymnody
Hi guys,
My friend has a GPU: Powercolor R9 270, and a samsung 24" monitor. His screen resolution are at max already but it is not taking up the full 24" space.
Any idea why and how to resolve it ?
Thanks for reading
JustAnotherTroll
press the auto adjustment button or go to the monitor settings and reset factory.
wrong forum btw.
devilwahaha
wrong forum btw.
Sometimes if the GPU keeps detecting it as a HDTV instead of a Computer Monitor, you can auto adjust or reset until button break there will still be underscan.
Fixing it with Catalyst is a more reliable way.
kimaking
Hi guys,
Thanks for reading
Go to your graphic card control panel (AMD) and go to VGA settings, there is an adjustment for you to set display at 100% full screen. Problem solve. I had this too when I first installed my card/driver and set my resolution to the recommended level.
