[Monitor] LCD monitor repair
BlueEye
Hi all, just curious if there's LCD monitor repair services around here and what are the charges like? Anyone with info feel free to post here or PM me. Cheers!
georgeleong
probably the cost of repair maybe 1/2 to 2/3 of a new one if there is any especially if the problem lies with the panel and not PCB or power issues.
jtjt00
For faulty LCD monitor beyond warranty, get a new one is the way to go. Unless it is one of your multi-monitor setup.
BlueEye
Shld be a PCB issue or power issue, coz no orange or green light when try to power on. Panel was working fine.
reflush
if the monitor button have light, but screen all blank, what possible wrong with the monitor?
bearusdamhu
If no power light, likely power board or logic card (difficult to repair) problem.. If power board still repairable, if logic card/processor chip, then difficult to find parts.. I got done a few with logic problem.. siannz.. can only savage it for spare parts..
btw, what's the model? maybe i am interested to buy lei.. hehe..
bearusdamhu
likely power/inverter board..
try flashing a torch light on the panel, can u see an image?.. IF yes, logic card is ok,, then have to troubleshoot the power/inverter board..
as with my previous post, whats the model #? am also interested to purchase if u are not into repairing it..
If u are willing to open it up (which is sometimes difficult for beginners), look out for bloated caps.. & if you do, PLEASE BECAREFUL.. high voltages are present on the Power board esp main Capacitor..
bebopbob
I had a similar problem on my Samsung SyncMaster 931bw, Only the power button light flash, I had to keep on try to turn it off and on for 15mins before the display will come on.
After reading about problem capacitors being the cause of such failures, I opened up the monitor and examined the power supply board. Two capacitors had bulging tops, so I went to Sim Lim Tower, bought soldering tools and two 1000uf capacitors and replaced them. My monitor is now fixed. Cost 80 cents for the capacitors.
bearusdamhu
Well done & Good job!.. :)
However, i am just concerned..
Just to share, that i did the same for my first few monitor repairs (i.e replaced ONLY the bloated caps).. But upon reading & communicating with other repair hobbyist, it is advisable to replaced ALL of them on the Power board EXCEPT the BIG FAT guy sitting in the middle.. Also the replacement have to be good quality Low ESR, High ripple caps (e.g Panasonic series FM, FC,etc) usually not found in Sim Lim. If not, (touch wood) the problem will come back a few/many months later..
Hope it does not happen to you la.. anyway, congrats for the repair..
bebopbob
thks, the monitor is over 3 years old, I will probably replace it if it fails in the next 3 years...:)
supergmail
do you do repair for others?
bearusdamhu
So far no la. I have offered to someone but he did not response, yet. However, i usually buy the faulty ones,,
Are you having problem with yours? What model & what is the exact problem with it?.
0benj0
Hi all,
If i on the main power, there is no power light what the problem?
Any recommend place to repair?
Thank!
bearusdamhu
Power board faulty is the likely cause.. have done many lcds but not led monitor repairs to pinpoint which area on the power board is the likely culprit.
supergmail
sync master 193t. there was some peeling on the lcd panel, then i try to remove it and it came out as a whole piece of stick on film. after removing it and puting it back into the case , the image on the lcd screen became very faint.
can still see the image but do background light or brightness set to very low. not sure it related to the film or i accidentally spolit the internal pcb.
any idea?
bearusdamhu
any idea?
hi bro.. sorry ah.. i abit confused.. u mean u disassemble the whole panel & remove the peeling?.. or u mean u just pluck out the peel part from the front part of the panel without assembly?. i cannot see how removing the peel-off can effect the PCB..
supergmail
it can be peel off without taking off the assembly, but i took out the assembly and peel it off anyway. after putting it back, it became the faint problem.
any idea?
bearusdamhu
any idea?
Honestly, not really sure what is causing the faint image. my guess is if the faint problem only at the peel off portion then maybe is due to the peeling.. if across the whole panel then could be something else...
