Monitor Loses Signal Intermittently..
gn1251
My monitor goes off by itself to off. The screen goes blank. Have tested with a different cable and monitor and still the same. I think it is the graphics card or motherboard problem. Or even software?
Anybody has experience with this? What should I do?
fleas1
can we have more detailed descriptions such as:
How old is your monitor, your graphic card
What OS are you using? win7 home 64bit? win8 pro 64bit?
When does it turn off? eg: after POST boot up/Windows loading screen
Any beeping sound?
gn1251
Any beeping sound?
I just changed the monitor 3 months ago. Also have tested with my other monitor and same thing happens.
Graphic card and the desktop is 4 years old.
OS is Win 7 64-bit.
It turns off any time when I'm using the comp. Not during start-up process. Sometimes about 10mins after I start the comp, in the middle of surfing the net.
No beeping sound.
Oh, and the computer is still on and working after the monitor goes blank.
fleas1
so when you are actively using your PC, your monitor suddenly turns off yes?
If that's the case, most likely its your graphic card causing this issue. If you have onboard graphics you can give it a try
jtjt00
4 years is good time for graphics card to go up lorry.
